Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Various CDMA/TDMA Cell Phones
Various CDMA/TDMA Cell Phones All CDMA & TDMA Cell Phones Related Threads are here
Old 08-17-2004, 04:02   #1 (permalink)
Member: 75838
Thanks Meter: 67
test mode
hi
i have a nokia2280 cdma phone, i need to test mode code of nokia 2280 and its commands.
thanks
Old 08-17-2004, 04:31   #2 (permalink)
Member: 37206
Originally Posted by sunil kumar
hi
thanks
might be you can tray to write *3001#12345#
and then in the menu you can chose field test
and chose eneble, then turn off your hand phone
then turn on again,
i have nokia 6510 for gsm can you tell me how to turn on the test mode,
thanks
Old 08-17-2004, 07:13   #3 (permalink)
Member: 27707
Thanks Meter: 6
You dont have test mode in Nokia 6510 gsm phone .. What do you need to do ..? Why you need test mode ?
reply .. Sunil
Old 08-17-2004, 09:20   #4 (permalink)
Member: 477
reply .. Sunil
There is Test Mode and Local Mode in all DCT4 Nokia models, you can put the phone into these modes with a command or via a hardware solution. On the screen of the Nokia appears: test mode or local mode and these modes are only for service purposes. Nothing more and nothing less.
Old 08-17-2004, 18:25   #5 (permalink)
Member: 75838
Thanks Meter: 67
spc code
reply .. Sunil
i want to know spc code without prl looseing do you help me?
Old 08-18-2004, 11:02   #6 (permalink)
Member: 37206
i need test mode to check the siganl from operator,
cause i work as engginer in telecomunication, and my job is to checked the signal,
can u give the code?
thanks
reply .. Sunil
Old 09-17-2004, 08:51   #7 (permalink)
Member: 82258
Local Mode
I have Nokia 2280 phone
when i switched on the phone it is showing "Local Mode"
what should i do?
Old 09-17-2004, 16:32   #8 (permalink)
Member: 67085
hi i just wanna know the use of test mode in nokia pphones
this cuz you can only read the information in these phones and cannot change it
if there is any way of changing such information plz share
thanks
Old 09-19-2004, 12:01   #9 (permalink)
Pluton's Avatar
Member: 20073
Thanks Meter: 250
All codes:
www.cdma-ware.com/codes.html
Old 09-20-2004, 16:14   #10 (permalink)
Member: 67085
hey
i wanna know the use of test mode of nokia 2280
i have opened the test mode but of no use
cuz it shows many things but the spc is hidden
so i want to know the use of the test modes in cdma phones
thanks in advance
Old 09-21-2004, 19:49   #11 (permalink)
Member: 72805
Hi All,
I have the solution for Nokia 2280. I have complete software to convert it from Reliance to other networks. But it does not change the ESN.
Anyone interesting buying, email me
Regards
Spider
[IMG] code is Off
solutions can't local mode,test mode,normal mode after reflash in here uwenk98 Nokia Hardware & Hardware Repair 30 07-27-2013 11:27
1202-1203-1661-1662 not charging test mode and local mode solution 100% tested /\/\A/\/| Nokia Hardware & Hardware Repair 14 07-11-2011 05:49
flash,local mode,test mode,normal mode big problem need help gsm_cdma_ufs Nokia Hardware & Hardware Repair 0 04-10-2009 10:50
1600 fleshing ok local mode/test mode ok but normal mode fail zargar322 Nokia Hardware & Hardware Repair 9 03-31-2008 16:22
Test mode, Local mode Normal mode royke Nokia Digital Core Technology 4 ( DCT-4 ) 0 08-13-2002 11:33
Page generated in 0.22881 seconds with 9 queries
