Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 11-16-2004, 12:38   #1 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
2100 hang / freeze and sometimes can not ON
I have 1 2100 which is hang then contact service and somtimes can not ON, i try to FULL FLASH, SET ORIGINAL IMEI, UNLOCK AND UPDATE FAID as usual, usually the phone will back to normal again, but this time i haviong problem, after finish all the procedures the phone still hang and the go back to contact service.
What is the HW problem, could it be the flash ic? i try to reball the flash ic, but still the same. CPU is glued.
The Following User Says Thank You to hooi76 For This Useful Post:
Old 11-16-2004, 13:20   #2 (permalink)
Member: 51453
Thanks Meter: 729
replace flash ic & your phone will be ok..hope this could help
Old 11-16-2004, 13:59   #3 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
Thanks mate, i will try it tomorrow.
Old 11-20-2004, 01:24   #4 (permalink)
hooi76's Avatar
Member: 7741
Thanks Meter: 111
yes it is the flash ic that have the problem, the sharps are no good
Old 12-26-2008, 06:58   #5 (permalink)
Member: 476626
Thanks Meter: 6
thanks bros it helps me....
Old 12-26-2008, 07:01   #6 (permalink)
Member: 476626
Thanks Meter: 6
i have onother prolem with 2100 it shows black in the only when turn on? please help!
Old 12-26-2008, 13:35   #7 (permalink)
Crazy Poster
Member: 763955
Thanks Meter: 16
Cool
have you ever tried to check the lcd or change? if not then try to change lcd... if still no good try to flash with correct flash before you proceed to the hardware solution...
hope it can help.
Old 12-26-2008, 16:11   #8 (permalink)
metro2mobile's Avatar
Member: 515972
Thanks Meter: 526
its ram pro........
chang ram
Old 12-26-2008, 16:23   #9 (permalink)
Registered User
Member: 804452
Thanks Meter: 248
nokia 2100 some second hang problam 100% solve
reboll flash & cobba ic than ur set ok tested me
Hariom
Old 12-31-2008, 14:46   #10 (permalink)
kurip's Avatar
Member: 526318
Sonork: dc2000
Thanks Meter: 42
Originally Posted by metro2mobile View Post
its ram pro........
chang ram
i thing 2100 dont have ram sir...ceck that.....its flash ic problem i think
3310 Sometime can turn on Sometime not NuengEve Nokia Hardware & Hardware Repair 11 10-06-2007 07:04
x100a hanging,freezing and reboothing obioha powerflasher 2 08-12-2005 06:32
3310 always can not ON and have to reflash hooi76 Nokia Hardware & Hardware Repair 4 12-24-2003 06:25
8310 can Flash but can not on mlngroup Nokia Hardware & Hardware Repair 3 09-21-2003 06:40
Page generated in 0.35013 seconds with 8 queries
