3210 Dead after Flashing I have a 3210 with contact service. Flashed it but found dead, even flashed three times with diff. flash version with knok but same dead. pl help thanx |
maybe was CS hardware :( BR Rak|m |
It may be to hardware but it shouldnt be dead after flash. it must show CS on screen. |
Write EEPROM......with good MCU+PMM and rebuild IMEI... WBR Imran Khatri |
Thanx Imranbhai but 3210 has external EEPROM, how to write it ? I dont know, pl help. thanx again. |
try to write full flash and if stell not work try to flash'it again and again with diferent soft version |
Write good virgin EEPROM.........if u r using UFS then it will be PMM.......... WBR Imran Khatri |
You must flash good MCU + PPM (ver 6.00 is newest) and your phone must turn ON !!! Update FAID change IMEI with nokia tool. If not turn on it's hardware problem becouse Eprom is 24c008 on the MB |
Imranbhai has right .. for eeprom use ponyprog |
use full flash as they say. MCU+PPM+EEPROM. |
I think faulty flash ic,its not accepting what u are writting.CHANGE IT. regards |
I think there are a couple of guys here that doesn't know what they are talking about. To write a new eeprom file you must remove the eeprom from the pcb and program it with a programer. But I don't think that it will solve your problem. I think it's a hardware fault, maybe flash Ic. |
