04-24-2007, 20:30 | #4 (permalink) |
Freak Poster Join Date: Mar 2007
Member: 461058 Status: Offline Thanks Meter: 8 | I don't know how UB works for 9210, try to refresh and download the flash files directly from the softwares interface. But Power Flasher (which is an UFS2) is not good at all, because of at the end of flashing it gots phone stuck instead of applying UI settings. The best tool I used for 9210 is WinTesla of course, then Griffin Box ! What you can do is flashing with PowerFlasher but you'll get some eror like Contact Service at the end, then you can apply UI settings with WinTesla. But if you have Griffin or WinTesla, so you'll be on point Jack |
04-28-2007, 00:47 | #6 (permalink) |
Member: 461058 Status: Offline Thanks Meter: 8 | Hey I don't know how the UB works with DCT-L 9210 , UFS can just flash it but you'll get Contact Service at the end, that you can fix by applying reset UI settings with WinTesla Select flash files properly MCU V4.13 + PPM A and do it at the end you'll have to install system files (alldata.sis) only on the memory card ! The only thing wrong will be the difference between German keyboard which is in QWERTZ and the English software which supports QWERTY Best Regards Jack |
