Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-06-2001, 03:13   #1 (permalink)
Blartiartfast's Avatar
Member: 4611
Thanks Meter: 68
Post 3310 Dropped in water
How do?
Someone has brought a 3310 for repair, which has been damp. I have cleaned the board with lighter fluid,(to cleaned furred up contacts"). A whole ago, somebody posted the common parts which fail under this sadly common fault, but i cannot find it. Does anyone know the common parts which fail, or where the link for this post is?
Much appreciated. Blart.
Old 07-06-2001, 14:26   #2 (permalink)
Member: 4403
Post
it power on? i have a 6110 droped in water and only lcd screen is screw up. i've change it and .... back in bussiness
maybe help
Old 07-07-2001, 01:56   #3 (permalink)
MDR
Member: 1272
Thanks Meter: 3
Post
spray with WD40 to displace water after an hour, spray with contact cleaner to displace WD40. assemble after an hour. power on
Old 07-07-2001, 09:08   #4 (permalink)
Member: 4611
Thanks Meter: 68
Post
Thanx for the replies. I will try the WD40 thing, because the phone is totally dead, and the battery discharched.
Thanx. Blart.
Old 07-07-2001, 11:14   #5 (permalink)
Crazy Poster
Member: 2806
I have fixed a lot of phones that have been dropped in water.
What i do, is basiclly to wasch the phone in a soap/water mixure (not the display).
The display is almost destroyed every time if dropped in water,and if the phone isnt powered of and battery is removed directly after dropped, you will have pcb tracks burned of.Wasch it really carefull and dont miss a spot, and let it dry up......and if you are lucky it will work,if not start replacing bad parts.
Boring work ,but it will get your phone back.
/Leeloo
3210 no signal after dropping in water eureka8888 Nokia Hardware & Hardware Repair 4 11-11-2008 14:46
n70 drop in water i clean it but in box give this problem جاسر مقدام Nokia Base Band 5 ( BB-5 ) 3 09-03-2006 10:18
3210 dropped in water, no network now!! aspog Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-14-2002 13:02
3310 dropped in water now display leds are shorted out and on all the time.please hel wildwhacker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 6 08-14-2001 16:01
3310 dropped in water ,still works but the display leds are on all the time wildwhacker Nokia Hardware & Hardware Repair 1 08-13-2001 03:50
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.12537 seconds with 8 queries
