11-21-2001, 18:08 | #1 (permalink) |
Junior Member Join Date: Aug 2001 Location: uk, essex
Member: 6062 Status: Offline Thanks Meter: 0 | 333 v4.30 Lead's Solution I have tried to use Leads solution, I have used dark flashers using all possible combinations of floaders and boot files.<br />I then used the bin files that were provided in the zip. I found that that the dark flasher settings are 656 and intel 16? When i use this setting to read the data from my 3330 I get Boot loader ready, Boot tx data error Then when I retry, it tells me that the phone does not respond, <br />If i manaually tuern the phone on and off then I retry, the boot loader is ready and the same error comes up. What is wrong? Anyone give me some helpful tips? |
11-21-2001, 21:29 | #5 (permalink) |
Crazy Poster Join Date: Nov 2001 Location: North Sweden, Lappland
Member: 7242 Status: Offline Thanks Meter: 0 | [quote]Originally posted by gurmukh:<br /><strong>Hiya Yeah sorry I meant to write 956. The speed of my PC is a Pentium 4 1.5GHz</strong><hr></blockquote> Isent that computer to fast? I can flash with my AMD 233MHz but not my Duron 1GHz. |
11-21-2001, 21:37 | #6 (permalink) |
Member: 6062 Status: Offline Thanks Meter: 0 | Hiya I have manged to get the files to work now, it flashes and read and writes but now when i flasht eh parital its unlocked with no signal, i modify the lock and the reflash with another partial the signal then comes up but now its not unlocked!!! |
11-22-2001, 11:38 | #9 (permalink) |
Member: 6062 Status: Offline Thanks Meter: 0 | Hiya I have made a backup from 55-60 and also 20-60 I tried the method again and this time the phone hangs on start up, just a pure black screen. I have now reflashed it with the 002-006 backup and the phone is back to how it was, still locked. Anyone shed some light on this? |
11-22-2001, 11:53 | #10 (permalink) |
No Life Poster Join Date: Feb 2001 Location: Fairyland
Member: 3383 Status: Offline Thanks Meter: 3 | OK SO U HAVE A WORKING PHONE WITH SIGNAL BUT LOCKED TO A SP.<br />TRY THIS :<br />1) MAKE BACKUP FROM 29-2A,SAVE IT<br />2) UNLOCK THE PHONE WITH THE FLS U HAVE<br />3) OPEN NOKTOOL 034 OR 033-READ PHONE- EDIT LOCK 1 WITH FFFFF & CLOSE LOCK1, U WILL GET MESSAGE "CANNOT CLOSE LOCK " OK , DON'T CLICK OK<br />4)REWRITE THE BACKUP FILE (29-2A ) FROM UR BACKUP<br />VOILA PHONE IS UNLOCKED TRY THIS & GIVE ME THE FEEDBACK - GOODLUCK EMAIL : [email protected] <img src="cool.gif" border="0"> <img src="wink.gif" border="0"> |
11-22-2001, 13:05 | #11 (permalink) |
No Life Poster Join Date: Nov 2000 Age: 47
Member: 2553 Status: Offline Thanks Meter: 3 | [quote]Originally posted by gurmukh:<br /><strong>Hiya I have manged to get the files to work now, it flashes and read and writes but now when i flasht eh parital its unlocked with no signal, i modify the lock and the reflash with another partial the signal then comes up but now its not unlocked!!!</strong><hr></blockquote> I had exactly the same problem like you, after flashing with the second partial, the phone was locked again. All you have to do is to change the flasher.cfg from Darks shell and change it with the one supplied from Lead and do everything like explained in his solution.<br />It works 100%<br />Regards<br />Meam <img src="wink.gif" border="0"> |
11-23-2001, 17:48 | #12 (permalink) |
Member: 6062 Status: Offline Thanks Meter: 0 | Hiya I didnt use Darks flasher, I used the flasher program striaght and put the loader bin fils in the nk_files folder It definately says that the 3330 is 65 08 in the cfg file. Still no luck |
11-27-2001, 01:02 | #13 (permalink) |
Junior Member Join Date: Oct 2001 Location: CZ
Member: 7036 Status: Offline Thanks Meter: 0 | HI<br />where can i find the second partial?<br />thanks [email protected] <FONT COLOR="#ffff00" SIZE="1">[ 27 November 2001 01:04: Message edited by: FilCon ]</font> |
11-27-2001, 04:00 | #14 (permalink) |
Member: 6062 Status: Offline Thanks Meter: 0 | If I replace my cfg file with the one that is supplied with Leads solution, then the dejan flasher tells me that the cfg file is bad, it needs at least 4 lines for it to work.<br />So i duplicated the 3330 line 4 times and now it works HOWEVER, the phone is still LOCKED!<br />Does this solution work? If so, what am I doing wrong? P.S - Every now and then Dejan gives me a Memory alocation error which can only be fixed by a reboot. |
Cruiser DB2020 Unlocking. Read This About Lead's Solution | yasin_shafi | Cruiser Suite | 5 | 05-31-2007 23:47 |
3330 v4.30 solution Tested on 2 phones | ByteMaster | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 03-26-2002 04:36 |
For exchange Solution to unlock 3330 v4.30 and v4.50 with 2 locks closed | Mehvishal | Exchange Section | 6 | 01-16-2002 08:33 |
ABOUT THE 3330 V4.30 SOLUTION | Lead | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 32 | 11-05-2001 22:42 |
