04-11-2005, 15:58 | #1 (permalink) |
Freak Poster Join Date: Jan 2005 Age: 47
Member: 107602 Status: Offline Thanks Meter: 2 | 3310 randomly restats.. i have an 3310 which restarts randomly, i have flashed the phone with ufs but the prob exists, any hard ware prob??,, if so please guide me??? BR |
04-12-2005, 21:26 | #6 (permalink) |
Freak Poster Join Date: Oct 2001 Location: Romania Age: 54
Member: 6797 Status: Offline Thanks Meter: 14 | If l511 is not enough, put flux and hotair on flash memory or better reball flash cip. I had same problem on about 100 pieces and 90% work after hotair. Try and see that it restarts usualy when you use left keys, where is flash cip on the back side. |
06-01-2005, 04:43 | #8 (permalink) |
No Life Poster Join Date: Apr 2005 Location: brunei
Member: 141262 Status: Offline Thanks Meter: 348 | audio IC audio IC can also cause the prob just reheat it would be ok!!! if not reheat flash IC.. if still have the prob.. replaced the 26mhz crystal osc.. gud luck mate!!! |
06-07-2005, 22:59 | #9 (permalink) |
Junior Member Join Date: Jun 2005 Age: 46
Member: 151375 Status: Offline Thanks Meter: 0 | i have the same problem too and have remove the 511,still the problem persit,the phone also tripoff, restart itself and display sim card not accepted. someone pls help thanks |
06-08-2005, 08:12 | #11 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: Turkey/Kastamonu Age: 52
Member: 133173 Status: Offline Thanks Meter: 119 | Quote:
06-09-2005, 16:08 | #12 (permalink) |
Junior Member Join Date: Apr 2004 Age: 47
Member: 62922 Status: Offline Thanks Meter: 1 | analize first your problem since you said that problem occur during pressing keypad then maybe there something causing a shorted on the board. Is the unit wet damaged? then try to clean it first then if the symtoms still persist then try to flash it then if still the same do the hardware procedure observe the part where you press key the look if what component near the key you press that unit begins to restart. then rehot / reball / replace the part. |
d900 problem random restat | F@RUK S | UST Pro II | 0 | 05-17-2007 10:29 |
T290i restat problem | naveedbutt008 | Sony Ericsson | 1 | 11-29-2006 09:24 |
X480 restats when sim is inserted!!!! | meisam | Samsung Hardware Repair | 1 | 02-02-2006 15:08 |
X480 restats when sim is inserted!!!! | meisam | Trident/AGERE Platform | 0 | 01-15-2006 22:19 |
3310 lights turns on/off randomly | kojote | Nokia Hardware & Hardware Repair | 13 | 07-02-2004 12:54 |
