5210 New Problem... Hello Guys!... Freezing .!!!... I have Nokia 3 Units Encountered 5210 Version 5.13.. Problem is when we ADD name on phonebook ot HANG! when we select GAMES same reason!.. HANG!... Also Profiles>Personalized>Ringing Tone... Same Problem!.. HANG!.. I try to Upgrade to 5.18 but no success.. Any body know about this problem?.. JammerOne... |
Hello... Try Cloning a 100% working unit. (00200000-00600000)... But do this only as a last resort... After cloning, make sure you do the following: 1. Cange IMEI to Original IMEI 2. Repair 4-Locks Closed Optional: 3. Restore Factory Settings 4. Set Authority ID (if reboot and no signal) If you still encounter same problems, then you are 100% sure that these are caused by some hardware faults because we are already 100% sure that we loaded a stable software. Possible Hardware Faults: 1. LCD caps (Common in 3310 and 8250 hang in in-box) 2. RAM Reflowing Needed (Hangs when some keys are pressed) 3. Damaged Xtal Clock (especially when games hangs!) Best Regards, X-Shadow |
I had same problem with 5210. They brought me one that hanged when trying to enter games. This also happened with one 3330 v4.50, and X-Shadows' "last resort" was 100% reliable for both phones. Best regards. Safrane. |
Yes X-Shadow had replied a very nice solution to you. Kindly full flash the phone from another working phone's back up. If you want the full flash file download it from here http://groups.yahoo.com/mygroups/haseebali |
