08-11-2000, 16:33 | #2 (permalink) | |
Freak Poster Join Date: Dec 1999 Location: Metro Manila
Member: 827 Status: Offline Thanks Meter: 0 | Please try this. 1|--0--|8 2|.....|7 3|.....|6 4|-----|5 Desolder pin 7 (Write Protect) and make sure it doesn't touch the board. Place a plastic sheet or what have you to ensure this. Then run a wire in this pin to ground then proceed as usual. As I've said, the pin 7 is the write protect. It prevents the EEPROM from being written to or deleted when it is connected to VCC (Pin 8). And itis disabled by connecting it to ground (Pin 4). This is the PIN configuration of the IC: 1-3 is the Adress Inputs; 4 is the ground (Negative); 5 is the serial data; 6 is the serial clock input; 7 is the write protect and 8 is the VCC (Positive) Please let me know if it works with you. I use this procedure and not the pin 6 and 7 short circuit stuff. Quote:
Deleted EEprom in NHM-5 | OrbiTel | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 21 | 01-25-2002 07:22 |
EEPROM IN 8210 | bluelights | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 10-10-2001 15:43 |
!!!HELP!!!! I need adress area of eeprom in 8850!!!HELP!!! | zdob | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 02-06-2001 00:43 |
Language change in NSE | Filin | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 07-11-2000 23:53 |
Problems on eeprom programming NSE-3 | Vizor | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 12-13-1999 23:26 |
