Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-05-2001, 13:06   #1 (permalink)
Member: 4873
Thanks Meter: 5
Post 6210 all 4 locks closed....
hi all!
i have this 6210 unit with all 4 locks closed, it doesnt register to any network... is there still a solution to this? it is a v3.01
Old 07-05-2001, 13:18   #2 (permalink)
MDR
Member: 1272
Thanks Meter: 3
Post
reflash it.
how did it happen?? what did you do??
Old 07-05-2001, 14:13   #3 (permalink)
Member: 5140
If you flash it with the correct partial, then all locks cleared.
Old 07-05-2001, 19:12   #4 (permalink)
Member: 4873
Thanks Meter: 5
Post
actually it i was so hard headed... it came from another shop... it doesnt have the same imei at the back cover but i still wanted to try and fix it
the problem is... i tried to make back up of this phone from a friend's flasher cable (just to test if its good ) but i didnt check if its a good back up or not ( STUPID HUH!) well it is not.. and so i used my old cable to flash it with 20-3d... because the "new cable" wouldn't read the phone.
the old cable has no problem booting, f_loaders, and reading the phone but when it comes to the writing part it says CMD error... i dont know what that means NOW when i try to power ON THE PHONE"S DEAD!!!!
(please guys try to read this essay) now i dont know what to do, i just need to power this phone again so i cud return it....
i had this problem before with a 3210, after flashing it lost its power.. i had a friend do it
* MDR - musta na pre? dami kopa talga di alam dito sa flashing2
Old 07-05-2001, 20:14   #5 (permalink)
rothmanns's Avatar
Member: 1544
Post
try using different f_loader... i use dark shell... i select normal loader for reading and the 2nd from the top loader for writting... but i doubt that we can fix the phone coz as u said... the eeprom was altered having different imei....
Old 07-05-2001, 20:34   #6 (permalink)
Member: 4873
Thanks Meter: 5
Post
yup, thats the advice for me but i dont know what to do and how to get it??
Old 07-06-2001, 04:04   #7 (permalink)
Member: 3900
Thanks Meter: 31
Post
Hi trafix...
I came across with same problem but get rid out of it with a help from Viper BJK.
Ask him... and he might help you pare..
Good luck na lang...
Old 07-06-2001, 05:01   #8 (permalink)
Allen's Avatar
Member: 2034
Thanks Meter: 24
Post
Pare! i hope you have not touched the PPM and the EEPROM part of the phones Flash Memory. The thing is when overwriting this contents possible cause will be: netwok goes on and off; 4 locks closed even if you flash it through partial flash file; imei changes to different variable other than the original imei in the phones back casing; phone always powers off without touching the power switch.
Backup first the PPM and EEPROM contents of the Flash Memory, here are the addresses: PPM=00520000h-005A0000h, EEPROM=005FA000h-00600000h, full PPM and EEPROM backup: 00520000h-00600000h
Use right f_loader to be able to overide CMD Error, the thing is your current f_loader file cannot properly communicate with the phone Flash Memory, check your email i have uploaded 2 loaders namely the f_loader.bin and unf_loader.bin, try this loaders i have successfully repaired several 6210 units. By the way the unf_loader.bin is universal it can read and write any flash types on nokia units except for the 6210.
Please take note that if you have erased the original PPMs and EEPROM all instructions and comments i have made will be totally useless, its important to take a note of it, I HOPE..
As for the moment i have no solutions yet for the EEPROMs system repairs. But for the PPM just look for a 6210 that has the same PPM version with your defective 6210 unitt, some 6210 PPM vary different versions, mostly likely there are 9 of them for all i know, this are PPM A to I.
Any comments and suggestions please email me at [email protected] or you can contact me on my wireless phone.
CHEERS!
+639173427696
Old 07-07-2001, 02:44   #9 (permalink)
Member: 4873
Thanks Meter: 5
Post
ok thanx.. ill try it as soon as i can my email is dead.. i just want to restore the phone back to power and return it... no harm done it was given to me without network
Old 07-08-2001, 19:32   #10 (permalink)
Member: 4873
Thanks Meter: 5
Post
guys... haven't fix the power yet.. any help is well appreciated...
allen- the f_loader doesnt work pre... i use green shell.. ill just give u a call
6210 all 4 locks closed ACE_UK Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-27-2002 18:35
6210 with 4 locks closed pascal77 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 12-07-2001 00:05
NOKIA 3210 ver. 4.02B All 4 locks closed Troll Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-31-2001 00:17
Nokia 3210 v.5.31 all 4 locks closed..please help Salute Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 01-27-2001 21:28
3210-EEPROM OK-ALL 4 LOCKS closed showing content EEEEE / FFFF JohnDoe Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 10-02-2000 21:04
Page generated in 0.16441 seconds with 9 queries
