6210 sec code pls help First sorry for bit older topic... I have part fls to change sec code to 12345 but does that fls work on every software version??? I also have program by gsmhacking but misses vcl40.bpl (not the dll file) could anybody send me that file... and is this program working?? Does it work with flasher cable or M-bus??? thnx. best regards, Salami1_1 |
Don't use this partial fls (192KB). On this way you can damage your phone. Program by gsmhacking is only for reading security code. You can reading sec. code with logomanager or KOCI v3.12. If your phone have blocked sec. code (5x wrong entered), solution is Nokia Tool V1.2 by Viper. But you must reading and writing all flash (200000-600000). I have fast and safe solution for this problem. Male me. Regards, Lord |
where could i get nokia tool 1.2? thanks in advance :) |
try to use Nfree software it resets the security code of ur unit |
I forgot to put in post that it was about a 6210.. and a friend of mine forgot his security code so only reading it will be ok to because then you can change it in the phone anyway.. Can koci 3.12 or logomanager read sec code with 6210?? thnx for the reply's and your hulp. regards, Salami1_1 |
logomanager can read security code of 6210 100%!!!! |
