Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 07-11-2002, 17:04   #1 (permalink)
Member: 12441
3330 no network after change tones with 5210 tones
I make my 3330 change tone to 5210 tones, I split PPM 3330 and use PPm Manager to change tones.Then I flash my 3330 with GSM Brother. Tones have changed, but I loss my network. I try to fix with eeprom tool, but no response or no changed.
Can any body help me how to make it step by step
Old 07-11-2002, 22:34   #2 (permalink)
Member: 5679
You need b-phreaks logger.First calck faid and then upload calk log file.....
Old 07-11-2002, 23:40   #3 (permalink)
Member: 3756
Thanks Meter: 5
Since you are using custom ppm you must use a FAID calculator that supports custom ppm...
Get Logger v2.0 by B-Phreaks here to read log from phone.
I never used 2.0 logger to update faid in custom ppm... but i suppose it works...
If it doesn't, just say something so i can send you 1.6.
And then use Tek's Faid calculator for B-Phreaks logs, get it here. Please note that you must specify the flash file you used (MCU+PPM together) when using tek's software.
Also, i heard that ringtone changing isn't possibile on new 3330 versions (4.30 and above)... i never tried though....
Best wishes.
Old 07-12-2002, 00:45   #4 (permalink)
Member: 12441
Still No network
I try your instruction both of you, but still no network for my 3330, my be right that MoOkIe heard. But sometimes when I changing ringtones the other type of Nokia phone still no network.
I try to use Dejan 104 flasher to change ringtones, the result is contact service. Maybe you can explain how to use dejan flasher 104 to changing ringtones.
Thank both of you before
@MoOkIe
Please sent me 1.6
Old 07-12-2002, 01:40   #5 (permalink)
Member: 3756
Thanks Meter: 5
Hi!
The reason for CS could be wrong PPM Checksums, you can use ppm manager to fix it.
I'll send you the logger 1.6, but for that i need your e-mail.
Plz post it here.
Best wishes.
Old 07-12-2002, 02:01   #6 (permalink)
Member: 9481
Hi,
If intending modifications in a flash file don't use:
3310-503, 3310-513, 3330-430 or 3330-450.
Because ppm manager calculates an incorrect flash checksum on those.
This flash checksum is required as input for calcing faid number afterwards.
So if the Flash check is incorrect, the Faid number will be calced incorrect too.
NokDoc
Old 07-12-2002, 02:07   #7 (permalink)
Member: 3756
Thanks Meter: 5
Just as i suspected!
Bye.
Old 07-12-2002, 08:47   #8 (permalink)
Member: 12441
@[MoOkIe]
My mail
[email protected]
Thank before
Old 07-12-2002, 09:18   #9 (permalink)
Member: 3756
Thanks Meter: 5
@PaRMaN
You've got mail, friend.
Bye.
Old 07-13-2002, 01:09   #10 (permalink)
Member: 13289
Thanks Meter: 32
MoOkIe, Please send me logger 1.6 for me.
My email [email protected]
Thank's
WBR
Old 07-13-2002, 01:22   #11 (permalink)
Member: 3756
Thanks Meter: 5
@andi_gsm2002
Please check your e-mail.
Bye.
Old 07-19-2002, 00:21   #12 (permalink)
Crazy Poster
Member: 13758
can you sendme
mookie,...please send me logger 1.6 for me
My E-mail : [email protected]
Old 07-22-2002, 01:58   #13 (permalink)
Member: 13289
Thanks Meter: 32
Thank's MoOkie.
To gun blade you can find in
http://groups.yahoo.com/group/andi_gsm2002/
K790 no network after wrong flashing with k800 file how to fix? fastlink Jogja Cruiser Suite 19 10-06-2008 17:28
please help no network after change imei Gabiunlock Universalbox 2 06-10-2008 11:08
No network after flashing U8500 with unlocked flash - What's wrong? James_S FuriousGold 9 05-10-2008 13:56
z300 no network after changing imei Excited NSPRO 2 08-26-2006 10:26
T630 No Network after change language! Help! .:HuyPQ-GSM:. Cruiser Suite 6 09-16-2005 12:24
Page generated in 0.22501 seconds with 9 queries
