06-01-2001, 12:17 | #1 (permalink) |
Freak Poster Join Date: Apr 2001
Member: 4398 Status: Offline Thanks Meter: 1 | 8210 contrast problem is there a program that will fix it does anyone ahve a program to fix this its and 8210 v5.25 |
06-02-2001, 15:39 | #4 (permalink) |
Member: 4398 Status: Offline Thanks Meter: 1 | i put the charger in and the bars came on as usual as though it was charging so i dont think its a contrast problem anymore. Also loads of random black lines came on and when i pressed the screen it went blank. do you think this is an lcd problem. |
06-05-2001, 03:16 | #10 (permalink) |
Junior Member Join Date: May 2001 Location: philippines
Member: 4771 Status: Offline Thanks Meter: 0 | greetings! i had the same problem with a 6210 before like after flashing there is no display and when during power on you will see random display of bars. why not try restoring the 8210 backup flash --assuming you have one. see if it works. ian |
06-05-2001, 17:37 | #11 (permalink) |
Freak Poster Join Date: Jun 2000 Location: laguna,philippines Age: 48
Member: 1544 Status: Offline Thanks Meter: 1 | remove six screws and separate the pcb with the lcd frame... remove the elastomer carefully the green thing connecting the lcd with the pcb... u can use elastomer of 3210 lcds just cut it into half with a clean blade... adjust the speaker connector.... try to put the backup flash first coz i think its more easier to do.... |
any problem i will fix it | sazr | Off Topic Zone | 0 | 03-24-2010 18:20 |
!! servers is down ¿when will fix it?? | ktienda | Universalbox | 0 | 12-14-2007 20:43 |
Need program that will Unlock V975 | joolsman | Motorola P2k | 8 | 05-16-2005 16:26 |
is there any program that can format locked mmc?? | Platijet | Universal GSM Software | 3 | 05-16-2005 13:05 |
Is there a program that could read PUK codes of SIM? | philkho | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-17-2001 18:52 |
