Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 01-20-2002, 06:01   #1 (permalink)
Member: 7220
Thanks Meter: 1,592
Unhappy Any Solution for auto 4 locks for 3310?
Hi,
I had came across 2 sets of 4 locks for the Nokia 3310. and all cases are geniune without using any flasher or software before. Whats wrong with it. The imei is intact. 4 lock in FFFFFF closed mode. Tested it on the Nokia Tool. Some people saying that it is the Cobba faulty. But how to solve it? Any solution without changing the cobba. Can I use a full flash or upgrading to remove it?
<br />Regards<br />Alan <img src="eek.gif" border="0">
<FONT COLOR="#ffff00" SIZE="1">[ 20 January 2002 06:03: Message edited by: xpmobile ]</font>
Old 01-20-2002, 08:19   #2 (permalink)
trashed's Avatar
Member: 8303
Thanks Meter: 127
Wink
it happened to me many times, ur error is you overwrite the original eeprom contents our fone. all u can do is upload the original eeprom which i think u have a backup.
Old 01-20-2002, 09:35   #3 (permalink)
Member: 7220
Thanks Meter: 1,592
Post
Hi,
Thanks alot. But this isn't caused by that. The phones just stated "SIMCARD NOT ACCEPTED" while coming out from the lift and network search <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> . This is an X-FILE that I ever came across
Regards<br />Alan <br /> <img src="eek.gif" border="0"> <img src="eek.gif" border="0"> <img src="eek.gif" border="0">
Old 01-21-2002, 18:27   #4 (permalink)
Member: 7176
hai my friend try unlocking using nu3000 or jethro6.22...if not solved its due to cobba chip complaint...try rehoting the chip.<br />please feel free to contact me for any kind of help..... [email protected]
Old 01-22-2002, 02:55   #5 (permalink)
Member: 3756
Thanks Meter: 5
Post
Hi!
I once had a 3310 with all 4 locks closed but IMEI intact....
I reflashed the same MCU+PPM (so that i don't have to calculate FAID) and hoted the phone...<br />I also reseted the phone to factory defaults...<br />After that phone was ok...!
C ya!
Old 01-22-2002, 05:40   #6 (permalink)
Bph&co's Avatar
Member: 1024
Thanks Meter: 5,510
Post
[quote]Originally posted by xpmobile:<br /><strong>Hi,
<br />Regards<br />Alan <img src="eek.gif" border="0"> </strong><hr></blockquote>
Hi,
This is very common problem. There is this start up self test which check the Cobba parallel interface, but it;s look like the test is not reliable enough.
This could happen if you have broken ball under Cobba ( loose conn. ) or more possible some small <br />quantity of water under the chip.
So the the data still flow between the DSP and Cobba , but small impedance between data pins cause errors one security data and locks are calculated wrong.
Observe Cobba carefully, rework, clean, reball or even change.
Best Regards, Alex
@lead any help for k700 4 locks? hrco Cruiser Suite 7 03-25-2005 17:55
still no solution for t65 4 locks misel Sony Ericsson 0 11-17-2003 08:12
Is there any solution for 3330 4 locks on EEEEE FFFFF??? mashco Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 12-24-2001 14:04
Need To Open 4 locks in 3310 Egypt Unlocker Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 12 12-04-2001 18:28
best solution for auto turn off on 3310 mudboy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 11-18-2001 20:05
Page generated in 0.17201 seconds with 9 queries
