Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 09-23-2005, 07:43   #1 (permalink)
Member: 89102
Thanks Meter: 12
Security code in 8110/3110
Hello I'm looking for security code fo nokia 3110/8110. I was trying 12345 but it isn't correct.
Thanks for relpy
The Following 10 Users Say Thank You to matysz For This Useful Post:
Old 09-23-2005, 09:12   #2 (permalink)
Member: 137735
Thanks Meter: 20
TAC FAC SNR SP
TAC = Type approval code
FAC = Final assembly code
SNR = Serial number
SP = Spare
*#7780# restores Factory Settings..(Memory, language, counters not included)
*#3110# for checking the phone's software (SW) - called firmware revision information.
#746025625# [*#sim0clock#]
Checks if the sim clock can be stopped. Sim clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#92702689# [*#war0anty#]
Press the following warranty code:
6232 (OK) : Displays the Month and Year of Manufacture (0997)
7332 (OK) : Displays the date of the last repairment - if found ('DATE NOT SAVED'...)
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
37832 (OK) : Set the Purchasing Date MMYY (Warning: You can only do this once - So be careful ...)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
Service Prover Lock
The service provider (SP) lock is used to lock the cell phone to the SP's SIM card. Once the cell phone is locked to a specific operator, if one inserts a SIM card from a different operator the phone will refuse to accept it! The cell phone will however accept another SIM card from the same operator.
All Nokia phones (2110 and newer) have four different SIM locks which can be used to lock the phone for upto 4 different providers. But most phones with restriction only have one lock activated. ( lock 1)
The main code used in Nokia phones is:
#pw+(master code)+Y#
This code is able to check, activate or remove Sim card restriction (SP-lock).
Use the * key to get the p, + and w chars.
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
(master code) is a 10 digit code, based on the phones IMEI number.
(I can NOT give you the master code - SO DON'T ASK ME FOR IT !!!!!!!)
Eg. To remove restriction on lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
Please NOTE that these codes could be used with care! A user told me that it's only possible to type in about 3 different codes on each lock! Then something bad will happen ..therefore be careful!
Bypass the SP lock
With a Nokia 16xx/21xx/31xx/51xx/81xx that are SIMlocked to one privider you can bypass the SP lock like this:
1: Insert sim card of diferent provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key.
4: Then Press * and wait until it desapear and apear again, then press * one more time and 04*PIN*PIN*PIN#
The phone now says: PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option !
Fast silent mode
In the newer versions (v.7.11 or higher) a quick silent mode can by entered. Press Menu then #.
The 54# Tip:
Type 1#, 2#........54# on the keypad (when you're not in the menu) to get the phone number used for with this key when speed dialing.
The Following 12 Users Say Thank You to calmant224 For This Useful Post:
Old 09-23-2005, 09:35   #3 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
Please use "SEARCH" option, see here:
http://forum.gsmhosting.com/vbb/showthread.php?t=235742
Bro.
The Following 5 Users Say Thank You to Phreackgsm For This Useful Post:
Old 09-23-2005, 09:56   #4 (permalink)
Member: 89102
Thanks Meter: 12
this phone ask me about security code when i turn him on so a cannot do anything more ;/
The Following User Says Thank You to matysz For This Useful Post:
Old 09-23-2005, 09:59   #5 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
For Master code reset, you need IMEI number and generate master code, into code in your phone, and reset your secure code.
Bro.
Old 09-23-2005, 11:07   #6 (permalink)
Member: 89102
Thanks Meter: 12
but how can I generate this code?? what i will need??
Old 09-23-2005, 11:09   #7 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
Ohhh my friend, see here:
Originally Posted by Phreackgsm
Hi.
Bro.
Solution here:
http://forum.gsmhosting.com/vbb/show...80&postcount=3
Bro.
Old 09-27-2005, 23:12   #8 (permalink)
Member: 95352
Thanks Meter: 3
I can't get the on-line code genarator to give me master sec code.
My imei no. 495032200218970
Can some help ?
Thanks
Old 09-28-2005, 06:52   #9 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
@ estadios:
Your Mastercode:
0712507176
Bro.
Old 09-29-2005, 17:04   #10 (permalink)
Member: 95352
Thanks Meter: 3
Thanks for your help, but code did not work.
Regards.
Old 09-29-2005, 17:18   #11 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
I generated this code with Java aplication, that model of nokia?
Now, you need box.
Bro.
Old 09-29-2005, 23:21   #12 (permalink)
Member: 95352
Thanks Meter: 3
What box do I need ?
Old 09-30-2005, 06:55   #13 (permalink)
Phreackgsm's Avatar
Member: 122
Thanks Meter: 18
Hi.
N-box, Twister, JAF, PBB, ....
But no response me, that model is your nokia?
For one phone, buy a box :/, box many €€€.
Bro.
The Following User Says Thank You to Phreackgsm For This Useful Post:
Old 10-04-2005, 05:38   #14 (permalink)
Member: 186946
8310
COULD ANYONE HELP ME UNLOCK 8310?
The Following User Says Thank You to ebrim-41thcma For This Useful Post:
Old 10-21-2005, 18:59   #15 (permalink)
Member: 192911
Question Help Me Please
HI
i want the code for motoRacer game.
my IMEI :356665000270116
nokia 6600
please help me
The Following User Says Thank You to sozana For This Useful Post:
when entering code in 8110, it says usim alreay unlock ashvin LG 6 09-11-2005 22:33
Resetting security code in 8110/8120 fonedoctorjnr LG 5 01-27-2005 01:09
HOW TO RESET SECURITY CODE IN NOKIA 6210 ed2k_7 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 10 05-26-2001 05:33
Page generated in 0.25257 seconds with 9 queries
