After full flashing 3210 v5.31 no network Hi, After flashing 3210 v5.31 with a full flash from "Fatum gsm" it can't find any network and the Dutch language is gone. Does anybody know where to find a WORKING full flash for the 3210 v5.31 ? Thanks ... :eek: |
hello there is nothing wrong with your full flash but now you ****ed up your phone becouse there is a difference in the imei nr in eeprom en flash !! there is for the time being no solution for this problem suc6 andre |
My i-mei is still the same, I flashed the phone frome 20 to 40 with the full flash from fatum. Is there a solution to read out a flash with a Atmel eprom ? Where can I find Siemens c35 flash files (1601/1701) ? Thanks. |
yes the imei is still same but the cheksum is changed . and you can not fix it ! dead phone :(( |
Try finding a similar phone in your area having the same version and language as with your original flash. Copy flash from it and load it into your phone. That should work. -aCe |
No this also dont help,phone is killed. You need somebody who has the Nokia TDF-Box, he can make a full flash and phone is alive. If you want-i know people in belgium,they can repair your phone,but you have to pay them for this. |
There is still hope... You must find Original PPM Pacakge for 3210 5.31. These files are for use with original Nokia Flashing Devices, but there is a trick on how you can use it with Dejan Flash Interface. Do not get the wrong impression that you can use this to update the firmware, this can only repair not upgrade. Once you get the Original PPM package, email me and I will convert them for you... Just dont try to play with your EEPROM! Best Regards, X-Shadow P.S. I think Y2K has Original PPM for 5.31 ;P |
I have experience, that u can use flash from the similar phone.. Because there is not EEprom found in flash.. A tried it on v 5,31 5,36 6,00 and it worked everywhere.. It is necessary to use phone from the same operator phone with same MCU and PPM package and it worx.. Correct me, if i am wrong.. Sincerelly Insider :cool: |
