another logging problem: i just bought some logs from b-phreaks<br />when i try to use the logger software v1.60<br />i keep getting error messages like(bad imei , phone not connected, couldnt reset mcu) i tried same cable and same fones with koci logger and my friend s jic box all ok got a proper log file .<br />what am i doing wrong ? is anybody there using b-phreaks logger help is well appreciated<br />thanks |
I use b-phreaks logger, i get the odd strange message but then i just read it again and all is ok. it says on his website that the phone must not be partial locked when u read, maybe thats the problem. regards<br />dan |
Hi. Use similar M-BUS cabel WITHOUT zener diodes on out!!! <img src="biggrin.gif" border="0"> -=Patent=- [email protected] |
Try logger 1.7, if you want it, let me know. or b-phreaks.. |
pls can mail me the new logger i am using 1.6 thanks in advance dan |
Hi guys, I hope all problems with reading 6210 are solved <br />in the v 1.7. What's new : - Start up self tests reading added. You can check the reason of your Contact Service. - Reset the phone to full factory. - For repair files customers - one step eeprom full update + set to factory. No need<br />to reflash after update. Please note if the Logger fail to reset to full factory after<br />IMEI & SP data update - security data start up test will fail. Please reset manually and<br />switch off and on the phone. We really like to add some usefull things to this soft so could be usefull to more people - the only<br />problem don't have the time to test the new things<br />properly <img src="frown.gif" border="0"> Please feel free to download it at: <a href="http://www.geocities.com/bph_co/" target="_blank">http://www.geocities.com/bph_co/</a> Best Regards, Alex |
