01-22-2004, 20:15 | #1 (permalink) |
Junior Member Join Date: Jan 2004 Location: MD Age: 52
Member: 48927 Status: Offline Thanks Meter: 0 | Nokia 6210 "security code" i have a problem with Nokia 6210 : in phone was soft v3.04, on power on asked "security code", i flashed phone with rollis (mcu + ppm), update FAID, clear SIM Locks etc with noktool by jordic, but again on power on "security code", i tryed wait 15 min, then enter "right" code (readed with noktool by jordic), but without success - "wrong code". How to resolve this problem? Any ideas? Thanks for help. P.S. sorry for my bad english |
03-26-2004, 13:51 | #2 (permalink) | |
Junior Member Join Date: Jan 2004 Age: 45
Member: 51184 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to robert_kcs For This Useful Post: |
03-27-2004, 21:25 | #4 (permalink) | |
Junior Member Join Date: Mar 2004 Location: slovakia, kosice Age: 40
Member: 59573 Status: Offline Thanks Meter: 1 | Quote:
no no no guys .... only what u have to do is : 1. write code 12345 2. setup, security settings, change access codes, change sec. code from 12345 to 12345. 3. change security level. that s all. U cant do anything else because cell tell CODE ERROR´. I have this problem with all 3310 when i make 3315. It is because u update faid. NICE day | |
The Following User Says Thank You to fesak417 For This Useful Post: |
03-28-2004, 01:42 | #5 (permalink) |
Crazy Poster Join Date: Jan 2004 Location: Romania Age: 53
Member: 49792 Status: Offline Thanks Meter: 1 | If you read the corect secutity i think you mast wait 30 ' or long , type code... end the problem!!! |
The Following User Says Thank You to suy For This Useful Post: |
04-02-2004, 02:05 | #6 (permalink) |
Freak Poster Join Date: Oct 2002 Location: Egypt Age: 57
Member: 17337 Status: Offline Thanks Meter: 12 | sorry guys but in 6210 if you entered the code more than 10 times the phone will block it self and you have to clear the security counter by knock phonix or write a good 4mb flash file (MCU + PPM + Eprom) |
05-20-2004, 22:22 | #7 (permalink) |
Freak Poster Join Date: Feb 2004 Location: SOMEWHERE
Member: 55062 Status: Offline Thanks Meter: 7 | Hi Guys Got Also A 6210 Failing To Reset The Security Code Got The Virgin Eprom Off Vrba Thanks But What Program Do I Use With It |
The Following User Says Thank You to TALLSAJ2 For This Useful Post: |
05-21-2004, 10:19 | #8 (permalink) |
No Life Poster Join Date: Nov 2002 Location: Nigeria
Member: 18200 Status: Offline Sonork: 100.1608286 Thanks Meter: 82 | You Are All Wrong You can try software for a million times, but phone will never unlock. You get the right code with rolis, etc, but when you inpute it, it says wrong code. Well this is 100% bad CCONT problem. It probably has bad soldered balls under. If you can, reball ccont, and your phone works again. To confirm what I said, ask the owner of that phone, he will probably tell you he NEVER used code on that phone; the phone just woke up one fine day and started asking for code. This is common wit 6210 8210 5210 Remember, if you cannot reball, DONT TRY IT, otherwise phone will die, and customer will tell you to "RETURN IT THE WAY IT WAS, MY COUSIN SAYS HE CAN UNLOCK IT UNDER 1 MINUTE" |
The Following User Says Thank You to dannyogolo For This Useful Post: |
06-25-2004, 10:26 | #9 (permalink) |
Freak Poster Join Date: Mar 2004 Location: Colombo, Sri Lanka Age: 55
Member: 58172 Status: Offline Thanks Meter: 13 | This is Correct As far as I am concerned the Security Code of 6210 can be removed only with WinDLS. Try WinDLS and you may succeed. WBR |
The Following User Says Thank You to Rahuman28 For This Useful Post: |
06-25-2004, 19:37 | #10 (permalink) |
Freak Poster Join Date: Sep 2003 Location: Warsaw, Poland Age: 54
Member: 38755 Status: Offline Thanks Meter: 3 | Use "Knok Phoenix Build 1a" for example. There's option "clear security code counter" you must reset counter when you put wrong code more than 10 times. Good luck. BR ZG |
The Following User Says Thank You to TELE-MEDIA For This Useful Post: |
07-20-2004, 17:59 | #11 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Fagaras Romania Age: 45
Member: 73571 Status: Offline Thanks Meter: 2 | try to repair with nokia dct3 calculator, then read with logomanager. if don't work, try with nokia tools 23 to aply sfs all positions ( one by one) |
The Following User Says Thank You to micutu For This Useful Post: |
08-27-2004, 17:40 | #12 (permalink) | |
Junior Member Join Date: Mar 2004 Age: 58
Member: 57729 Status: Offline Thanks Meter: 1 | Quote:
YES IT WORK, tested by me ! | |
The Following User Says Thank You to uwogsm For This Useful Post: |
11-19-2004, 17:52 | #14 (permalink) | |
Freak Poster Join Date: Mar 2004 Location: Epinal Age: 71
Member: 56335 Status: Offline Thanks Meter: 26 | Quote:
this eeprom is too small, whith rollis I've still an error message "File size must be n*64KB (n=1,2,3 ...)". What can I do? | |
The Following User Says Thank You to coupdephonie For This Useful Post: |
11-19-2004, 18:08 | #15 (permalink) |
Insane Poster Join Date: Aug 2002
Member: 14358 Status: Offline Thanks Meter: 1 | Use this software. Using Rolis, read eeprom from 05A0000-0600000. Run software and open flash file you just backed up, then save the file. Open the new eeprom file in rolis and write to 05A0000. Job Done. 6210, 6250 and 7110 Security codes cannot be reset like other DCT-3. This is the one of th only SAFE ways to do it. |
The Following User Says Thank You to surfy For This Useful Post: |
Nokia 6800 "Security Code???" | madcrowmax | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 06-20-2008 03:11 |
6600 "security code" | trinacria46 | WD2 & APE (Symbian Phones) | 6 | 09-23-2004 17:41 |
Nokia 6310i "restriction code" | bozzoso | Phone Unlocking Codes & Maps | 10 | 10-31-2003 09:55 |
6510 shows "Security code" plz help a.s.a.p | the_frightener | Nokia Digital Core Technology 4 ( DCT-4 ) | 3 | 05-17-2003 13:05 |
I have locked nokia 6210 with 5.36 flash. Nokia flasher gives such error: | dimon | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 12-30-2001 23:51 |
