Does Nokia Tool v1.5b by Rolis work? Someone sent me this file and I'd like to know if this program works ok? |
Try it? Try it... And yes it works! Best regards! |
i used to use my cable with noktool s/w and it reads the fone fine when i use the v1.5b br rolis it does nothing the erroe at the bottom of the screen say m2bus error |
hi the cable must be only M-Bus and not F/M-Bus!!!! the proggi works the unlock-buttons alone works not, you must press to "all open". its works. regards Winner 58 |
The programs works for me with F/M-bus "dual" cable, for faid & for "unlock-button". I tested it! |
Phil: Check Mail :) Yes it works, if you need pure MBUS cable just call or email me... |
Yes it works.... Only inportant thing missing is the ROM-indicator which EEPROMTools from BPhreaks has. Maybe Rollis can implement this too. That would be nice......................:D :D (now lets hope Rollis reads this ;) |
Hi Thanks for suggestions and opinions. Best results are with m2bus cable like for nk_calc.com. If anyone have cable schematics,which aren't supported ,you may send it me personally. @DCAvdP :Rom version?It's verry easy to make,but does it necessary ?I'm disabled IMEI+Splocks initialisation on ROM3, so you don't have to worry about ROM version or sw type. You don't damage old rom3 phones,even if you wish. Check link www.rolis.freeservers.com for updates or news until i've get better server. BR, rolis |
Leave the ROM3 on please!!!! Y????? Why??? Why did u disable ROM3???? :-( I have this 5110 4.59 ROM3 that i try to fix...downloaded your sw (thank you very much!!) but it tells me it won t support ROM3!!!!! :-( I need to fix my no network problem...i have fixed both IMEIs (not sure how!) probably with Nk_calc and WinTesla but now, no Network and reboot!!! If anyone finds any solution!!!! Cheers!! P.S. @Rolis thank you for your reply on that other topic!! |
to Rolis Nice tool ;) but i have one question to U may be You make one programm with flashing,unlocking, MCU&PPM update, and FAID calculation ??? As i am, if U insert this functions in 5.14 flasher or higher - it be very very cool prog thanks. P.S. Sorry for bad English |
100% work good tool. B.r. Henry :eek: |
hi all i can't download any one can send to me |
i have it waleed contact me online i'll send it to you... good luck! |
This program is mad! I would have to say its the best for changing IMEI! Well done rolis bro! |
@Mad4IT : read my (and other ppl) post about ROM3 problems here : http://forum.gsmhosting.com/vbb/show...threadid=33817 Software upgrade for ROM3 i'm not removed,cause it works Ok. Just IMEI and Sp locks. Like said Alex "........ - To all who asked about DSP 3 - sorry my source is your source. Maybe you have to ask the man for the missing hash tables ........" :) @Sturmovogel : it are already maked,just until i'm not finished, it will be not released. I think , here must be not very big problems move from flasher to m2bus software.Additional - needs to include more functions in flasher (remove useless partials at least ...) @welly2000 : you must go on html page and press on link,then shoose download option on IE (disable GoZilla,DAP,...etc.) @TheEckoMan : here are great sw too from Bph&co and Tibor (kNok) To all : better do not post greetings,100X"send me too",just bugs reports ........ or happens like with posts: http://forum.gsmhosting.com/vbb/show...threadid=34208 http://forum.gsmhosting.com/vbb/show...threadid=34179 Regards, rolis |
