Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 03-19-2005, 05:39   #1 (permalink)
GOODNESS's Avatar
Member: 89584
Thanks Meter: 68
3310 can flash but cant on
i got 3310 that i flash.it accept flash but cant on.help please
Old 03-19-2005, 06:25   #2 (permalink)
pazeth™'s Avatar
Member: 74519
Thanks Meter: 79
check power swicth on/off
Old 03-23-2005, 13:39   #3 (permalink)
freedomizer's Avatar
Member: 123931
make sure you flashed mcu and ppm with same version.
after flash you have to do reset factory defaults and user settings and locks. otherwise the phone will not start as the new flash checkums need to be set.
If still no go, and it's a soft problem, then flash pmm and rebuild imei, then flash mcu and ppm and reset all settings, if still not starting then it's some hardware fault.
love,
freedomizer
Old 03-27-2005, 11:17   #4 (permalink)
Member: 75424
change the MCU and PPm version
Old 04-14-2005, 00:58   #5 (permalink)
Member: 69633
Thanks Meter: 2
Flashing PMM after MCU and PPM will do the difference, if there is no hardware damage. :-)
Old 04-17-2005, 14:44   #6 (permalink)
Administrator
..::Neo::..'s Avatar
Member: 14178
Thanks Meter: 8,862
moved from dct-4 ...
Old 05-01-2005, 15:29   #7 (permalink)
robbyslam's Avatar
Member: 114921
Thanks Meter: 16
rehot flash ic...........
Old 05-01-2005, 15:43   #8 (permalink)
cellco_mann's Avatar
Member: 78448
Thanks Meter: 17
Flash with latest MCU and PPM files set will ok.
Old 05-06-2005, 00:25   #9 (permalink)
Member: 142956
we advise u 2 change the flash IC .
bye
n-70 can charging but cant on !! joecheun Nokia Hardware & Hardware Repair 4 09-11-2007 06:26
3310 can flash but cannot power on mt-boy Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 5 06-11-2007 05:31
3310 can flash but not power on?! sergo_zmeia Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 04-27-2004 21:46
3310s can flash but dont power up douda Nokia Hardware & Hardware Repair 15 04-16-2003 09:59
Page generated in 0.22485 seconds with 10 queries
