Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 11-24-2003, 23:06   #1 (permalink)
Member: 4653
Thanks Meter: 3
does it possible to chnage imei on 2100 witj griffin dct3 dct4 imei rebuild ?
hi all
thks
GYZMO
Old 11-26-2003, 06:10   #2 (permalink)
Super Moderator
acyl2000's Avatar
Member: 1922
Sonork: 100.64645
Thanks Meter: 689
sorry...you can't..
Old 12-01-2003, 17:17   #3 (permalink)
Member: 24373
Use MBus cable and Knok. At "Phone settings" use "Set new IMEI". Reset phone settings, reset full factory settings and reset phone. Use Nokia Tool 3.21 to unlock and set faid.
BR Marian
Old 12-10-2003, 19:13   #4 (permalink)
Member: 4653
Thanks Meter: 3
its no easy
not working your solution , at the begining can not change imei
Old 12-10-2003, 19:19   #5 (permalink)
Member: 24373
It`s always working for me! Use Knok Build 1(By Nutzo) for 2100 or Knok by XPMobile.
BR Marian
Old 06-20-2004, 19:22   #6 (permalink)
Member: 65618
Post plz how can i get knok flasher for Nokia 2100
plz how can i get knok flasher for Nokia 2100 , i read that
within knok flasher i can resolve 'contact service' for
warranty state failled
thanks
Old 06-20-2004, 20:31   #7 (permalink)
XenKo78's Avatar
Member: 9955
Thanks Meter: 7
some NOKIA 2100 have OTP imei so is impossible to change it even by full flashing or rewriting vigin eeprom.
If u whant to change imei change flash chip
Old 06-21-2004, 10:33   #8 (permalink)
Unlocker AL's Avatar
Member: 3617
Thanks Meter: 499
With Knok Phenix
try with full flash mcu-ppm and after this steps
1-With Knock phenix change imei and you put original imei
2-quick said faid
3-restart Sp Lock
4-restart phone
Go to Nokia Tool v3-21 jordic
And make Special factory setings SFS
And restart
And your nokia is ready
100% tested
Old 06-21-2004, 16:35   #9 (permalink)
Member: 69297
Thanks Meter: 7
hei...is it possible to change nokia 2100 IMEI with sharp IC???? not intel ic
Old 06-29-2004, 19:43   #10 (permalink)
DeltaGSM's Avatar
Member: 65947
Thanks Meter: 134
no you can't...
please search & read post result.
Old 06-29-2004, 21:05   #11 (permalink)
Aamir_Zia's Avatar
Member: 47321
Sonork: 100.54032
Thanks Meter: 485
Cool
BR Marian
MAN !!!
2100 have Sharp IC ( OTP IMEI )
means Imei writes only 1 times & then Locked
No one can change the IMEI !!!
We just rebuild it
If you really want to change the IMEI
Then You have to Change the FLASH IC !!!
Regards
Aamir Zia
Old 06-29-2004, 21:22   #12 (permalink)
unlocker4494b's Avatar
Member: 32308
Thanks Meter: 2
for 2100 it exist stand alone flasher
for 2100 it exist stand alone flasher to change the IMEI
I have used it too search in the forum or contact with www.simsim.ae he have it 100% !!
Old 06-30-2004, 04:28   #13 (permalink)
Member: 69297
Thanks Meter: 7
hey...unlocker4494b what do you mean by stand alone???
as long as i know and used right now is griffin and ufs 3....
can you explain more about this?
and as long as i know sharp ic is just can write once not more
whar is the device name that you said before?
Old 06-30-2004, 09:06   #14 (permalink)
Member: 47133
This flasher is build direct for 2100
This flasher is build direct for 2100 with repair function download it from:
http://www.unlocking.hu/2100/index.htm
Old 06-30-2004, 09:22   #15 (permalink)
Member: 32308
Thanks Meter: 2
With this flasher you can repair the I_MEI too
Flash your phone and write I_MEI
I have repaired 2100 with this solution .... use normal flash cable
does it possible to unlock lg u900 penialav Basic Micro-Box Software Support (SAMSUNG, HUAWEI, etc...) 2 12-11-2008 17:06
Help!!!! Does It Possible To Flash 6630? Venus2309 Nokia Base Band 5 ( BB-5 ) 7 05-10-2005 14:39
Is it possible to activate Crusader on plastic Griffin ?? GSMassistance Griffin 3 11-06-2003 20:18
Is it possible to remove SIMLOCK on NEC DB 2000? Bogi Various 0 06-23-2002 17:36
Is it possible to change imie on T20s mcrozz Old Ericsson Phones & Sony Phones 7 03-01-2002 07:07
Powered by Searchlight © 2021 Axivo Inc.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2021 DragonByte Technologies Ltd.
Page generated in 0.20224 seconds with 8 queries
