falshed 3210 with wrong start address, can anyone help? I flashed my 3210 but i entered the wrong start address, it should of been 260000 but i put in 270000, i cannot remember what version the phone was and i do not have any other 3210's to copy flash from, anyone help, ACE |
Copy partial flash of your 3210 from the following addresses : 002B0000 - 002C0000 Open the partial flash dump with any text editor. Now, try to do a search of the following "NSE-8". Above (or a few chars before)the search result, you will get the version of your flash (i.e V 05.10). As for full flash backups, try searching through the forum, you'll find a couple of sites that distribute full flashes for free. Regards, aCe |
Hi, You should always make backup! Just flash it from 00270000 to 00300000 when you find out wich version it is! Best Regards |
Find the version (as above method), let me know, and I will create a repair flash file for you. |
hi prodigal, i cannot read the 3210, it does not respond, but i have a 3310 with the same problem, it is version 4.18 and it for some reason does not come on after flashing even though the start address was correct (280000) ive got the flash out file from it so if you could do anything with the that let me know and ill e-mail it to you, thanks ACE |
Hi Prodigal I got the same problem of inputing wrong add. for my ver.6.00 3210. Can you give a repair soft for this... thanks in advance.... fils [email protected] |
