Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-18-1999, 18:32   #1 (permalink)
Member: 195
Crack For WT6.03 Found Here ...
Hi there,
I didnīt try this crack, but you will find a crack on:
http://free.poltronic.net/~bontek
CU
Hyperlite
Old 06-19-1999, 18:08   #2 (permalink)
Member: 194
Thanks Meter: 2
on my page u will find nwe version of
working crack for wintesla 6.03 !!!
try this
regards
Old 06-20-1999, 05:57   #3 (permalink)
Ryu
Member: 131
Thanks Meter: 11
I got the same problem... I thought the crack works perfectly... however, when i open a module, it'll go illegal operation....
Pleaes help!
[This message has been edited by Ryu (edited 24 June 1999).]
Old 06-23-1999, 23:24   #4 (permalink)
Member: 154
why is that i cannot run wintesla 6.03. when i open it asks for the dongle, then i press cancel, next is it asks for the login id, i press again cancel, when trying to open nse-3, it displayed : " an error has occured in your program to keep working anyway click ignor & save your work in a new file to quit this program click close. you will lose information your entered ."
then I pressed cancel & it responded :" this program has performed an illegal operation & will be shut down"
Please help.... Thanks
Old 06-26-1999, 16:38   #5 (permalink)
Member: 96
You have to cancel the first dialogou but as login enter "RA".
Old 06-26-1999, 17:11   #6 (permalink)
Jefferson
Guest
Posts: n/a
Member:
forgot the login dialog!!!
just push ok or cancel without a
name in the dialog!!!
this option is just in use if you
modifyed tesla to "fault_log"
it's just if you have direct connection to
nokia mobiles !!!
so let it be...
regards
Crack for WinTesla 6.03 here! RealNijntje Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 01-09-2002 12:02
WT6.03 Problems LaurentF Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 11-25-1999 23:30
Crack for WT6.03 (STESLA.EXE) is FAKE !!! 5110 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 06-22-1999 08:50
Page generated in 0.16182 seconds with 9 queries
