05-10-2002, 00:11 | #1 (permalink) |
Freak Poster Join Date: Mar 2002 Location: Bombay , India Age: 41
Member: 10543 Status: Offline Thanks Meter: 0 | File size must be = n*64kb ? |
05-10-2002, 16:42 | #2 (permalink) |
No Life Poster Join Date: Nov 2001 Location: England Age: 41
Member: 7653 Status: Offline Thanks Meter: 823 | open the file in a hex editor, find the total size. now divide this size by 65536 and round the number down to its nearest significant figure. times that by 65536 and you will have a size that rolis can use. open the file again in a hex editior and use select block and enter that value you calculated as a decimal number. copy/paste and save now you have a workable full flash. however, if the file was cut down rwrong in the first place, i guess trimming again will erase the ppm checksum at the end of the file. result=contact service. download your files from decent sites in future |
05-11-2002, 20:21 | #4 (permalink) |
Junior Member Join Date: May 2002 Location: GREECE Age: 40
Member: 11561 Status: Offline Thanks Meter: 0 | Use wt2dejan099f to convert these WinTesla flashes to dejan ones, then join mcu+ppm together and you will get a working file to flash it with knok or rolis. |
<<<there must be automatic log file creation for each operation>>> | StRaNgE PeRsOn | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 12 | 02-18-2010 04:59 |
W800 Battery Voltage Or Usb Transfer Size May Be Too Low! | DJst0ne | Cruiser Suite | 0 | 12-27-2007 11:10 |
Battery Voltage Or Usb Transfer Size May Be Too Low! | NeTRaW | Cruiser Suite | 7 | 07-21-2005 09:12 |
Siemens C45: This must be new? | ed2k_7 | x1x to x45/x50 | 1 | 11-07-2001 12:25 |
The information must be free,OK? | paulomt1 | GSM Mobile Links | 0 | 02-11-2000 20:39 |
