FlashBOX Modified by VsH-GsM FlashBOX Modified by VsH-GsM Whats new:<br />-automatic Start&End address writing in read flash section<br />-new nokia phones added<br />-a lot of flash loaders & boot loaders corrected<br />-full flash & mcu & ppm addresses added to program<br />-some tools added<br />-three bugs fixed download it : <br /><a href="ftp://ftp.noetec.at/nokia/PROGS/FlashBOX.zip" target="_blank">ftp://ftp.noetec.at/nokia/PROGS/FlashBOX.zip</a> |
wow that was quick .. thanks for the upload, and making it opublic .. <br />you DA man !! Mick ... |
link is down... i'll try later... |
Hi! I can't suck from that FTP!! please try to upload somewhere other! thx, cu |
- For all here: <br /><a href="http://www.terra.es/personal4/nkmont/test.htm" target="_blank">Landy´s page</a> BR Landy.- <img src="eek.gif" border="0"> |
i'm working in a modification too... i have install your EXE but Flash box don't start... some problem in your code i think... |
hey .<br />wanderful.<br />mm by the way i want to wite some for my problem.<br />i flashed my phone 5110 from 0020000-0040000 just for education.(it is tru you cannot have knowledge if you don't **** your phone at the beginning)):<br />anyway and there was CS .i flashed it again with original %100 working flash.bun to lıck.<br />it is said to me that there can be a problem with the eeprom (24c16).so i downloaded ponyprog.and epromunlocked.(but i cannot find eeprom burner):<br />there is sheme with eeprom unlocked is there any1 tried this.<br />if i made a mistake bye to phone.<br />thanks<br />(i can read it normally with nokiatool) |
after install setup file,dont work.<br />whats prob???? |
I and my some friends tested it and it has not any problem!<br />This program doesn't tested in Win2000/XP.<br />what error you got?<br />i have these runtime files in my system directory (IN WINDOWS ME) and the "FlashBOX.exe" successfully working:<br />-------------------------------<br />COMCTL32.OCX (VER:6.0.80.22)<br />DAO350.DLL (VER:3.51.1608.0)<br />FLASHBOX.DLL<br />MSCOMCTL.OCX (VER:6.0.88.62)<br />MSVCRT40.DLL (VER:4.22.0.0)<br />RICHED32.DLL (VER:5.0.1461.82)<br />MSVBVM60.DLL<br />-------------------------------<br />VB5DB.DLL (MAY BE NEEDED)<br />VBAJET32.DLL (MAY BE NEEDED)<br />MSRD2X35.DLL (MAY BE NEEDED)<br />MSREPL35.DLL (MAY BE NEEDED)<br />EXPSRV.DLL (MAY BE NEEDED)<br />MSJET35.DLL (MAY BE NEEDED)<br />MSJINT35.DLL (MAY BE NEEDED)<br />MSJTEY35.DLL (MAY BE NEEDED) |
Hi!<br />I found a little problem in FlashBOX Setup :<br />you should not run FlashBOX from start menu after installing!<br />please run it from:<br />\Program Files\FlashBOX\flashbox.exe Good Luck!!! <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> |
flashbox original/modified doesnt run on windows 2000. got the error message: flashbox.exe has generated errors and will be closed by Windows. You will need to restart the program. An error log is being created. is there anyway of modifying it so that it WILL run under windows 2000? vhs-gsm, how about you release your modified source code as well? <img src="smile.gif" border="0"> |
hi pks!<br />send me error log please.<br />my mail : [email protected] |
Here is my experience with Ice Dragon's FlasherBox: I installed the setup.exe. I ran it from the start menu. Doesn't launch! I launched it from the directory c:\programmes Files\flashbox.. Doesn't work. I created a directory c:\flashbox and copied all the files in the c:\programmes Files\flashbox directory into it and ran it from c:\flashbox. It works. Tested a 3310. I can read the phone. I unistalled the soft and kept the c:\flashbox directory. Doesn't work. I reinstalled it. it works but only from c:\flashbox. That's all. Hope this helps. |
These are screenshots of program: [img]ftp://ftp.noetec.at/nokia/splash.jpg[/img] [img]ftp://ftp.noetec.at/nokia/prog.jpg[/img] TRY IT!!! <img src="smile.gif" border="0"> |
if you have all of this files in your system directory,you wont have any problem.<br />[img]ftp://ftp.noetec.at/nokia/files.jpg[/img] Thanks for your trying & reporting problems <img src="biggrin.gif" border="0"> |
