11-16-2001, 16:08 | #1 (permalink) |
Freak Poster Join Date: Sep 2001 Location: Galaxy far far away!
Member: 6428 Status: Offline Thanks Meter: 43 | Help! 3310v4.23ppmA All 4 Locks Closed! |
11-17-2001, 17:50 | #4 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | I try to edit the full 20 to 40 original backup to 3E0000 to 400000."Eeprom fls." After I got this original eeprom fls of 3E to 40, I dump this flash to the fone from 3E to 40. After writing this flash, I read the flash of fone from 3E to 40. Then I check the flash out file if this will match to the orig. eeprom fls. Then it matched. I removed the flasher cable then I turned on the fone. When I turned on the fone, the fone hangs for almost 20 secs. then it appears CS, then afterwards it turns off. I read again the fone from 3E to 40. After reading, I found out everytime I pressed the power on fone, the eeprom fls. of the fone became corrupted or destroyed. Can you give me an advice regarding this problem? By the way, Ambot, thanks for the flash that you gave me. This will help a lot m8.<br />Thanks... <img src="confused.gif" border="0"> <img src="confused.gif" border="0"> <img src="smile.gif" border="0"> <FONT COLOR="#ffff00" SIZE="1">[ 17 November 2001 17:54: Message edited by: Dj King ]</font> |
11-17-2001, 20:12 | #5 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Philippines
Member: 4274 Status: Offline Thanks Meter: 18 | don't full flash the phone with the one that i have sent to you because you will change the imei... flash only without eeprom area... much better you should check first your original full flash with nfree and you can repair the corrupted backup using this software... |
11-19-2001, 17:49 | #6 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | Yes of course. I flashed it w/out the eeprom part. I know that if we flash the fone w/ diff.eeprom flash, surely it will change the IMEI and surely it will find no network and will reboot. Ive already tried to repair the backup w/ Nfree 1.2 or 1.3 but still no luck. <img src="confused.gif" border="0"> |
11-19-2001, 18:10 | #8 (permalink) |
Member: 6428 Status: Offline Thanks Meter: 43 | What part of the circuit/hardware should I look first? Will you pls give me the step by step guide how to troubleshoot this problem? Thanks m8. <img src="smile.gif" border="0"> <img src="confused.gif" border="0"> |
11-19-2001, 18:15 | #9 (permalink) |
Member: 4274 Status: Offline Thanks Meter: 18 | i'm not yet familiar with hardware problem on 3310. you can **** hotair to CCONT and make sure software were already repaired if ever there is a problem... |
need help K608i all 4 locks closed | chitawira | Sony Ericsson | 1 | 12-01-2006 07:09 |
T68i all 4 locks closed. HELP | PhoneDoctor | Old Ericsson Phones & Sony Phones | 8 | 06-19-2004 14:39 |
NOKIA 3210 ver. 4.02B All 4 locks closed | Troll | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-31-2001 00:17 |
Nokia 3210 v.5.31 all 4 locks closed..please help | Salute | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 01-27-2001 21:28 |
3210-EEPROM OK-ALL 4 LOCKS closed showing content EEEEE / FFFF | JohnDoe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-02-2000 21:04 |
