Help to unlock 3210 ver 5.22 and higher Who can help us to unlock this phone. We need Nokia 5110 ver 5.28 too. Thanks to all. ------------------ |
You may need to use Nokia tool pro (build 033 or higher). (But I not tested it) |
If you don't have an TDF5 box and all other stuff needed, you can either wait for a program to come, or you can flash downgrade the flash chip in the phone... But this is not so easy... |
No Nokia tool pro (build 033 or higher) can remove the sim lock. I have build 034 and have closed all locks permanently. |
mmm. since newnoktoll build 034 can't do 5.22 of a 3210 and a 5.28 of a 5110... can somebody test: 1] nokia 2000 by dr. koz 2] neo's master unlocker ver 0.1b and give us feedback... the lastest nokias i unlocked are 3210 5.10, 5110 5.24, 8210 5.13 [5.11 of 8210 is givin me a headache.] all these worked with nokia tool build 033. ------------------ |
I Have TESTED: 1] nokia 2000 by dr. koz 3210 up to ver 5.10, ver. 5.22 does not work, nolia 5110 works up to ver. 5.27 2] neo's master unlocker ver 0.1b that´s the same. Thanks to all who wil help us. |
And also! I have tried the 8210 & 8850 new solution with the 5110 v5.28 using 9v battery. Phone just hang, so I remove the battery and back again. When power on phone, phone still OK but still lock! Any solution for this version!!! |
Hi all, I've tested 3210 Ver 5.26 with nokall 5.9 by Virtual Z and it works. Jim T |
HI ALL I CHECKED 3210 V. Till 5.26 ON NOKIA NETWORK UNLOCK PROGRAMM V.8 BY ZULEA And ALL WORKED I DON'T TESTED V.5.28-ANYBODY UNLOCK IT???? ------------------ slayer |
i unlock them with changing 5.27 flash and unlock it then put 5.28 flash back but it takes about 12 min if someone help me i will be apreciate |
Hi king76, Can you send me the flasher & flash file for nokia 5110. Thanks, |
hi all i testet all námed progis to 3210 v5.31 without result all locks where the same (closed) also testet the progis for 8210,8850 v5.22 and 5110 rom4 v5.28 no chanche! my best regards y2k |
