02-15-2002, 16:32 | #1 (permalink) |
Insane Poster Join Date: Jan 2002 Location: Romania
Member: 8505 Status: Offline Thanks Meter: 0 | HEX study - first results!!! The sub at 06F2 actually reads 13 bytes from PC and is the sub for MSID decoding. It returns to the PC 4 bytes with PPM CHK, 4 bytes with COBBA_ID and 3 check bytes:<br />First byte MSID ---- check bytes should be<br />81 ---- A5 A6 A7<br />82 ---- A8 A9 AA<br />83 ---- AC AD AB I have written a program that emulates the PIC to decode the MSID number. I have to put it somewhere online. Most probably it will at http:\\www.geocities.com\ldril\ |
02-15-2002, 17:15 | #4 (permalink) |
VIP-Member Join Date: May 1999 Location: home
Member: 69 Status: Offline Thanks Meter: 0 | @daniel<br />checksum for 81111111111111111111111111<br />could it be that cobbaID starts with 2A....<br />and faid with EE9C..... <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> best regards Y2K [ 15 February 2002: Message edited by: Y2K ]</p> |
02-15-2002, 17:19 | #5 (permalink) |
Member: 8505 Status: Offline Thanks Meter: 0 | What exactly do you mean by cannot calculate? How did the program behave? Any error messages? What was the output? Do you have the hex file in the same directory? Anyway for me it works:<br />Flash chk: 941BD1C8 Cobba ID: 2A15CFB9 Check: 6EE49AA867<br />(ofc as you can see this is not a valid MSID) |
02-15-2002, 17:30 | #6 (permalink) |
Banned Join Date: Nov 2001 Location: IRAN Age: 38
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | @drill<br />Hey!!!<br />You are great!!!<br />Good work!!!<br />Keep on your Excellent work!!!<br />Please send me a source of your program to : [email protected] !!!<br />I want to Make Log Calculator...<br />Thank you! @Y2K <br />No,Can not |
02-15-2002, 17:54 | #7 (permalink) |
Member: 69 Status: Offline Thanks Meter: 0 | @VsH-GsM <br />hehe could be for 10000% belife me <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> daniel know what i'mtalking about <img src="wink.gif" border="0"> |
02-15-2002, 18:14 | #10 (permalink) |
No Life Poster Join Date: May 2001 Location: Glasgow, Scotland
Member: 4690 Status: Offline Thanks Meter: 1 | Wow!<br />If source is released (or if you work on it now!) I expect a log calculator to be out within hours! Forgive me for my ignorance but as I understand it - that program extracts flash, cobba, and check from readed MSID?<br />In which case, all that needs done is the faid calc algo, which takes in these values, to be "emulated"?? Well done idril!!! |
02-15-2002, 18:18 | #11 (permalink) |
Member: 8505 Status: Offline Thanks Meter: 0 | I think the MSID can start only with 81, 82 or 83. Other values might not give an answer at all... and the program does very few checks for good input data. So GIGO (garbage in garbage out <img src="smile.gif" border="0"> ). If the first 3 bytes of check are not what I described earlier, then I guess the MSID is not right. ldril |
02-15-2002, 18:40 | #12 (permalink) |
Member: 8505 Status: Offline Thanks Meter: 0 | [quote]Originally posted by DavieB:<br /><strong>Wow!<br />If source is released (or if you work on it now!) I expect a log calculator to be out within hours! Forgive me for my ignorance but as I understand it - that program extracts flash, cobba, and check from readed MSID?<br />In which case, all that needs done is the faid calc algo, which takes in these values, to be "emulated"?? Well done idril!!!</strong><hr></blockquote> You're right, the values are decoded from MSID. I'm working to find out how the FAID is calculated. <br />For this I need some input and output of the loggers. Can someone send some logs to me pls? ldril |
02-15-2002, 19:27 | #14 (permalink) |
Member: 7444 Status: Offline Sonork: 100.99999 Thanks Meter: 10,013 | ***************** OUTPUT LOG FROM LOGGER *****************<br />[ppm_ver]<br />in=Here is Phone version in hex format [imei]<br />in=Here is Phone imei in hex format [msid]<br />in=Here is Phone MSID [data]<br />in=Here is Some bytes:<br />1st Bytes <img src="tongue.gif" border="0"> hone ID<br />2nd Byte <img src="tongue.gif" border="0"> PM Info<br />3th Byte:MSID Checksum<br />4th Byte <img src="biggrin.gif" border="0"> SP internal version<br />************************************************* ********************<br />*************** CALCULATED LOG FOR LOGGER ***************<br />[ppm_ver]<br />out=PPM ver in String<br />out=IMEI in DEC<br />out=MSID<br />out=FAID<br />out=FAID CHECKSUM<br />************************************************* ********************<br />Here is faid checksum calculating algorithm by VsH-GsM:<br />FAID Checksum: B8 + phone_id + all numbers of FAID<br />example:<br />Phone ID :2C (6150)<br />MSID : 821EE569C7B8F7E7CCECF3F204<br />FAID : 3D09CB14F43B4292702CFC37<br />FAID CHECKSUM : B8 + 2C + 3D + 09 + CB + 14 + F4 + 3B <br />+ 42 + 92 + 70 + 2C + FC + 37 = DB<br />************************************************* ******************** |
02-15-2002, 19:45 | #15 (permalink) |
Freak Poster Join Date: Jan 2002 Location: U.K
Member: 8465 Status: Offline Thanks Meter: 0 | [quote]Originally posted by ldril:<br /><strong>This message is a follow-up (with a small correction) for:<br /><a href="http://www.gsmcity.de/ubb/ultimatebb.php?ubb=get_topic&f=20&t=001687" target="_blank">http://www.gsmcity.de/ubb/ultimatebb.php?ubb=get_topic&f=20&t=001687</a> The sub at 06F2 actually reads 13 bytes from PC and is the sub for MSID decoding. It returns to the PC 4 bytes with PPM CHK, 4 bytes with COBBA_ID and 3 check bytes:<br />First byte MSID ---- check bytes should be<br />81 ---- A5 A6 A7<br />82 ---- A8 A9 AA<br />83 ---- AC AD AB I have written a program that emulates the PIC to decode the MSID number. I have to put it somewhere online. Most probably it will at http:\\www.geocities.com\ldril\</strong><hr></blockquote> hi idril excellent work.........!!!!!!!! |
ODM v3.03 First result W375 dead | ab1009 | IQ-Box | 11 | 07-01-2007 00:59 |
Searching for smart clip hex 2.18 for 3 months with no result! PLEASE HELP! | boria | Hardware Equipments for GSM | 0 | 11-09-2006 00:44 |
HEX study - let's combine our knowledge | ldril | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 02-14-2002 23:47 |
First results for C 30 unlocker for beta testers | bobik | x1x to x45/x50 | 12 | 06-15-2001 11:08 |
