Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 04-07-2001, 19:17   #1 (permalink)
Member: 2752
Post probs with 8210 v 5.21
Phone has screen problem (screen info looks staggered across the screen)
And also powers down in the middle of a call.
Any Ideas?
I do have a good 5.21, what areas of the flash can I upload to the bad phone to get it working, or is it hardware fault.
Help appreciated...
Old 04-08-2001, 11:15   #2 (permalink)
cris's Avatar
Member: 2375
Thanks Meter: 4
Post
Hi,
First you must verify hardware problem. Change batery and try to solder power circuits.
regards,
Cris
Old 04-08-2001, 11:35   #3 (permalink)
Member: 2752
So you think the power down prob is a power supply prob, I suspect this also.
however do you think this would affect the screen (I have seen this on a friends phone also, and he ended up having it replaced)
Old 04-08-2001, 16:23   #4 (permalink)
Member: 4011
Post
screen is ok ,there are no software or firmware faults,just open 8210 screen and remove green contact "elastamas" and replace "elastamas"from 6110 or 702,402 replace into back of screen and remember to lift earpiece legs out .good look any problems e-mail me
Old 04-08-2001, 16:31   #5 (permalink)
Member: 4011
Post
3310 screen if faulty or need replacing,simply take one out of a 3210 and replace,works the same,100 %.
Old 04-08-2001, 18:59   #6 (permalink)
Member: 2752
Cool
Thx for advice,
I will try it tommorrow.
Old 04-09-2001, 02:14   #7 (permalink)
Crazy Poster
Member: 2124
Post
Did you test your 8210 without cover?, some times the cover is the problem, and you only have to replace it.
BillyJoe
Old 04-09-2001, 10:26   #8 (permalink)
Member: 4011
Post
all 8210 have "elastamas" fault the green contact behind screen,simply remove old elastamas and replace with new from 6110 or 402,702 models ,dont forget to lift earpeice legs out ,screen will work 100% ok and problem will dissapear.i know because i fit 10 phones everyday,and my customers think they need new screens.good luck
Old 04-09-2001, 22:02   #9 (permalink)
Member: 2752
Cool
Dismantled phone today and removed screws from main board.
Removed keyboard/screen assembly.
Cleaned contact pads on main board for battery contacts and cleaned edge of screen contact strip ("elastamas").
reassembled the phone and ensured that all screws were tight.
Result:
Upto now problem free, screen ok and also made 15 minute call without power prob.
Thx for advice.
8210 v 5.26, 5.25, 5.21 flashez needed urgently! Invader Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 01-28-2002 21:23
Problem with 8210 ver 5.28 cobba Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 11-15-2001 15:09
8210 v 5.21 DEAD simonb Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 2 07-24-2001 13:33
8210 v.5.21 Ros Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 0 03-23-2001 17:39
Nokia 8210 5.21 unlocking! pioter Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 1 10-07-2000 16:01
Page generated in 0.20361 seconds with 9 queries
