02-27-2001, 16:41 | #6 (permalink) |
Freak Poster Join Date: Oct 2000 Location: Europe
Member: 2382 Status: Offline Thanks Meter: 0 | The Dejan Flasher you can buy at www.gsmclip.com And the pin 5 trick is cheaper to unlock if you have one phone to unlock. |
02-27-2001, 20:51 | #9 (permalink) |
No Life Poster Join Date: Dec 2000 Location: Slovakia, Brezno
Member: 2721 Status: Offline Thanks Meter: 23 | For pin 5 trick you need to dimantle phone, for dejan flasher not. For flasher you need a special cable using LPT port, search discusion for details.... |
02-28-2001, 19:28 | #10 (permalink) |
Junior Member Join Date: Feb 2001 Location: uk
Member: 3479 Status: Offline Thanks Meter: 0 | tryed this 5 pin trick but in tfe instructionsit say's when u touch pin 5 and tell it to read phone u should get funny imei displayed "651:1:1:1:1:1:1" i cant seem to get this any ideas what can be wrong |
02-28-2001, 21:30 | #11 (permalink) |
Freak Poster Join Date: Dec 2000 Location: UK
Member: 2752 Status: Offline Thanks Meter: 0 | Hi, I recently did a 3210 5.36 using pin 5 trick. I had to press unlock button a many times before It unlocked any of the locks. my advice , press unlock 4 or 5 times while earthing pin 5 with your body. Then read Locks (dont earth pin 5 while reading locks) Then try again...and again....and again, until all locks are open. Worked for me.. ------------------ Syko [email protected] |
03-01-2001, 03:01 | #14 (permalink) |
No Life Poster Join Date: Sep 2000 Location: UK York Age: 56
Member: 2008 Status: Offline Thanks Meter: 4 | You cannot unlock this phone with dejan as locks are in "REAL" EEprom and not emulated in flash I think? The easiest way would be the pin 5 trick and yes you will have to take the phone completely to pieces and then partly put back together, then do the pin 5 trick while phone is turned on and connected to Nokia tools When you get funny IMEI, you can then press unlock 5 times and then remove pin and press unlock once more this should then open lock repeat this for all locks. funny IMEI does not have to be "651:1:1:1:1:1:1" but it will only be similar. To ground yourself use something like touching the non painted part of your PC Hope this helps Charlie |
V600 need help fast please | Hagan | Smart-Clip | 2 | 12-28-2006 09:06 |
Z800i dead - need help fast :( | phone_abuser | TOTAL MultiServer | 14 | 07-08-2005 00:48 |
Need HELP fast!!!! | ForEvo | Samsung Flashers, Software, Firmware. | 12 | 09-02-2004 21:18 |
A50 Dead- Need Help Fast!! | gsmphone | x1x to x45/x50 | 31 | 02-20-2004 17:04 |
need help fast, gd87 | maka | Panasonic | 0 | 10-29-2003 23:55 |
