Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 04-23-2002, 14:50   #1 (permalink)
Member: 11214
Looking for best flasher soft for full flashing nokia 3310 with simple lpt cable
Looking for best flasher soft for full flashing nokia 3310 with simple lpt cable (74CH14 ...etc) . And solution how update flash without problems. Please help !
Old 04-23-2002, 15:50   #2 (permalink)
hacker1gsm's Avatar
Member: 5113
Thanks Meter: 10
hi mate
u can use dark limmeing soft
or use knok soft
regards
Old 04-23-2002, 17:51   #3 (permalink)
Member: 11214
How i can identify my flash type and boot loader ?
Old 04-23-2002, 18:24   #4 (permalink)
Member: 10558
hi
knok is an automatic software all u need to choose is the file and the phone type it's very good prog but tooo slow if u need another one u can use rolis 4.71 or 5.14 it's woking 2
best regards
the LORD
Old 04-23-2002, 18:41   #5 (permalink)
Member: 9740
hi
use for example darkflashershell 2.14, 2.15, 3.01.
(even If phone don't turn on):
bootloader= "964"
flashloader= "normal"
Flash id = "00898890"
place a file in backupfolder (FULL backup) first.
make the settings above..
press backup, your file should appear in menu in left
select it and choose 3310 as model.
press flash.
in dejan(starting when you hit flash) do this.
F2--enter until it says you should plug cables in phone.
do that then press enter and after that press on button on phone shortly.
Computer hangs up(at least mine)
a few minutes later it says done in down left corner.
unplug.
If you used your own backup turn on phone and it should work.
If other backup connect to mbus cale and update faid.
/Atlantis
Can I flash Nokia 6233 with CA-53 cable? Daviath Nokia Base Band 5 ( BB-5 ) 4 05-12-2010 12:30
Flash nokia 6600 with serial com cable???? fgkrew WD2 & APE (Symbian Phones) 0 07-26-2007 22:26
Flashing Nokia 3310 with Griffin AVS32 Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 4 06-09-2004 19:24
Can i Flash Nokia 3310 with ... Badroufun Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 7 01-18-2004 21:33
help to flash Nokia 3310 with russian language pack AGr Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) 3 01-11-2004 09:24
Page generated in 0.16319 seconds with 9 queries
