Nokia 2100 5.56 After Flash Can't Upadte Faid I FLASH JUST PPM ON MY 2100 5.56 WITH GRIFFIN SW2.07 BW2.50 AND NOW NO NETWORK. I TRY TO SET FAID WITH ALL OTHER TOOLS BUT NOTHING SAME PROBLEM. IF SOMEBODY HAVE SOLUTION PLS HELP URGENTTTTTTTTTTT |
You have to forget to uncheck "Factory reset" after flash with griffin. Now just stay phone with valid SIM inside for few hours. The network will come |
thanks for advice i will try and post results here |
I had try to live it for few hours and phone was found network and work fine but after power off and on again phone show NO NETWORK again. I don't know what is the problem! any idea thanks |
your imei starts from 351 ? |
HI check ur imei Regard rise |
I didn't check what to do if starts with 351??? Thanks |
IMEI start with 352 and same problem again :(( help??? Thanks |
There is more phones like this. My friends from Belgrade had told me that there is more nokia 2100 version 5.56 with IMEI 352... witch after flash show NO NETWORK!!! |
flash mcu+ppm to phone and use faid calculator using mbus by tek. |
maybe the IMEI you have flashed is BARRED from your network. check if the new IMEI matches your original value |
This is common problem,i didn.t manage to solve this ,knok,rolis , |
Griffin didn't helped to.Maybe there will be griffin update with this bug corrected |
