Nokia 3210 5.36 full flash needed...! D1.. Hi to all, i was unlocking a 3210 V 5.36 with Nokia Flasher and an error in erasing flash stopped everything! Now phone doesn't turn on and i need a full flash...if it works! The sw is Area A; product code 0504979, locked to D1 Please send me links or full flash at [email protected] Thanks in advance! |
Maybe this will help: http://www.regionet.pl/~fatum/gsm/pliki/3210-536B.ZIP |
Thanks a lot, i knew this site, but i think this version is of Area B. However, i found the version i needed! Thanks a lot! ------------------ Francesco Ponticelli - Napoli - Italy ICQ# UIN 20785673 WebMaster "Ponticellinks.Com": http://www.ponticellinks.com |
hello never put a full backup from other phone in your phone your phone will be gone !! the result will be : not locking to network for the time being only nokia servicecentre can repair your phone |
I know this problem, but if you put the same version, with the same product code, you shouldn't have any network problem, because the checksum are the same. For example: if i have a 3210 v5.36 AREA A, it's different from 3210 V5.36 AREA A but locked with D2, because the are different pack in flashing. But if you have two 3210, V5.36, locked with D2, and with the same product code (wich is the central point for these things), you can flash, because they are the same. Bye! |
You can flash any phone with full-flash if eeprom is outside Flash (like 5110, 6110, 6150, 3210,..) br Myke |
