10-07-2004, 11:04 | #1 (permalink) |
Banned Join Date: Jun 2004 Location: GSM HEAVEN Age: 36
Member: 69984 Status: Offline Thanks Meter: 170 | Nokia 3310 Displays "Not Charging" Some Body help me... |
The Following 3 Users Say Thank You to .:.GSM-ANGEL.:. For This Useful Post: |
10-07-2004, 21:17 | #3 (permalink) |
Freak Poster Join Date: Jul 2004 Location: Fagaras Romania Age: 45
Member: 73571 Status: Offline Thanks Meter: 2 | 1. your charger is working not properly 2. you have a CHAPS batery charger damaged or unsoldrered 3. you have a brocken pcb circuit and try to verify the other answer's to same pb |
The Following User Says Thank You to micutu For This Useful Post: |
11-18-2004, 17:11 | #7 (permalink) |
Junior Member Join Date: Aug 2004 Age: 54
Member: 77055 Status: Offline Thanks Meter: 0 | mates not all not charging in the phone is a hardware problem let me share to you what i do first before opening to do hardware first i test the battery terminal with multitester b+ to gnd it should be 3.6v if not its hardware. i use wintesla energy management and run it you'll see not charging will vanish upon running it its too easy than opening the phone i've tested it and use it for a long time especially nokia 33 series. |
11-19-2004, 02:48 | #8 (permalink) |
Cheater -Don't Deal with him- Join Date: Mar 2003 Location: ITALY
Member: 23994 Status: Offline Thanks Meter: 43 | @aadil268... check this site- www.centralpark.net.au |
12-06-2004, 15:40 | #10 (permalink) |
Member: 77055 Status: Offline Thanks Meter: 0 | sir for me, its simply a very good software and its really effective. energy management calibration is one of its function, base on it function and explanation on how to run it. wintesla is a software that can possibly putting the values of its component to its normal function. easy to say, it can correct a small problem or values differences to a standard values or funtion. |
01-01-2005, 07:30 | #13 (permalink) |
Freak Poster Join Date: Aug 2004 Location: PUNJAB (INDIA) Age: 47
Member: 78448 Status: Offline Thanks Meter: 17 | I have wintesla software but when i try to run it then it gives error nokia dongle not found.I m using normal flashing cable in paralll port.Can any one help me where is the problem?????? |
01-03-2005, 19:43 | #14 (permalink) |
Insane Poster Join Date: Oct 2004 Location: bhopal Age: 51
Member: 85008 Status: Offline Thanks Meter: 4 | 3310 not charging When I put charger pin into Nokia 3310 it displays "Not Charging" tried all the solution of this form still same problem pl can anyone try to explain with circuit diagram for tracing the problem ,as nobody tried deeply to solve the problem as this is serious fault in nokia 3310 |
Nokia 1100 start up display "not charging" | ammhai | Nokia Hardware & Hardware Repair | 5 | 02-20-2010 19:01 |
Nokia 7610 shows "not charging".plz help. | jana1_2008 | Nokia Hardware & Hardware Repair | 19 | 07-24-2009 12:44 |
6111 displays "not charging" | André_F | Nokia Hardware & Hardware Repair | 7 | 03-13-2008 15:00 |
5100 displays "not charging" | zullu2004 | Nokia Hardware & Hardware Repair | 0 | 11-27-2006 10:39 |
Nokia 3310 says "not charging" even with new charger | mmjulian | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-23-2006 04:47 |
