Nokia 6110 IMEI change.... I am looking to change the IMEI number on my cell. I think it may have been stolen....because when I bought it second hand worked for only a short while and then shut down. Thanks |
It's illegal to change you're IMEI... |
Yeah, but so is having a copy of Wintesla, or walking across the street not at a pedestrian crossing, or copying some software or music cd on your rom writer for a mate....I've got a problem, where someone did me a dirty and sold me a problem phone...all I need is some help on this please. |
OK, I don't know if you have been looking though the nokia forums... Couse without a security box and some other stuff from nokia the only way to change IMEI is to go into the phone and reprogram the eeprom or do some chaning with the flash and coba chip, and this is not very easy... But maybe some day there will come a program so all we have to do is hook it up with a usual mbus cable.... And by the way I did not want to teach you morals... [This message has been edited by dito (edited 24 May 2000).] |
Thanks for the info dito.... No offence taken and I certainly hope none taken by you.... :0) Keep well! |
use IMEI changer. what you do is copy a binary file from a new or old 6110 and put in in yur hard drive. when the imei changer opens a bin file, redirect it from the file u save and just change the last 2 digits to any number you want. lets just hope taht no one uses that particular number. ------------------ |
But what particular IMEI Changer software you use? There are lots of software for changing IMEI in nokia but nothing seem to work! Did you test it yourself? Thanks, |
tested it w/ a 5110 and a 6150 both older versions [4.++] and it worked. so i assumed it will work with a 6110. the program is called easy imei changer. ------------------ |
this imei changer doesn't work ...............tested on all the ports and you'll see it for yourself.. Regards:VATO ------------------ Vato Loco... |
This program doesn't work...tested for yourself on all the com ports and it wont read the phone at all..........Regards: VATO ------------------ Vato Loco... |
