03-27-2002, 05:59 | #1 (permalink) |
Major Poster Join Date: Mar 2002 Location: south wesst
Member: 10046 Status: Offline Thanks Meter: 0 | b-phreaks & dejan though the FLS device looks interesting, though where can you get DCT4 cables from |
03-27-2002, 07:23 | #2 (permalink) |
No Life Poster Join Date: Feb 2000 Location: UK
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, It is a factory made board with programed PIC and components - all quality SMD parts and the 25 pin connector. This is intended to fit in 25 pin plastic shell of normal Flasher cable sold everywhere. You just have to solder the lead from original board to this one and fit it inside - 5 min job. It is perfect for hobbyst and people who do not want the hassle of making board at home or buying PIC programmers. Please mail Daniel - I'm sure he can add a 83/65 connector to the FLS device for small extra charge. BR, Alex |
03-27-2002, 07:56 | #3 (permalink) |
Freak Poster Join Date: Feb 2001 Location: england
Member: 3348 Status: Offline Thanks Meter: 3 | wow would this device be the dejan box then. that does that mean you would be able to use all the soft that only works with dejan box 104/105. if so will it com with box id no built in and is it 104 or 105??? sorry for the stupid questions m8 many thanx [email protected] |
03-27-2002, 09:46 | #4 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, No problem We talking about two different things here - Dejan box is just a board with parts soldered. The FLS device is a complete interface for most programs using Dejan type of flashing interface and Mbus comunication. The main point is that you do not need to change any leads while repair , update or unlock Nokia, because this device is software controlled. Please feel free to download the schematics from our site and see better how this works. BR. Alex |
04-03-2002, 05:01 | #5 (permalink) |
Junior Member Join Date: Dec 2001
Member: 8041 Status: Offline Thanks Meter: 0 | re: fls-2 hi Alex.... i got fls-2 schematics from bphreaks k & i'm not sure wher the lines Vpp & Btemp go??? i want to build (& almost complete except for those 2 lines!) & now i hav incomplete board lying on my desk! as i understand it u can use this with s/w to flash & Btemp used to power on fone so say manual.....think Vpp used when writing/erasing flash, so i'm told...... well, manual stil dont say wher those lines go??? mite go to dummy batt. on original equipment but not sure...... is there another circuit that goes after those lines? wut am i missing? any help gr8ly apreci8d........... BR nokia_tec |
04-03-2002, 09:58 | #6 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, Vpp line is used mainly for 3210 Flashing. Reason is that the internal DC-DC convertor can't provide enough voltage for Flash Programming( 2.4 V supply from battery ). If you have a 3210 pinout you'll find which pin is this. Btemp line is used for auto start of the Flash process. If you have a close look at any Nokia battery you'll find 2 additional pins in the middle. One of them is called Btemp ( it has a internal temperature sensor and does exactly this - measure the battery temperature) - also is used to boot up the MCU in MAD2 by a short pulse. You can connect this one to 51/61/71/62 phones by making a small modification to a normal battery - open it and connect this wire to the Btemp pin. For 3210 - you have available pin on the back slot - the factory made flasher interfaces have this one connected already. Hope this helps. BR, Alex |
04-06-2002, 08:04 | #7 (permalink) |
Member: 8041 Status: Offline Thanks Meter: 0 | hi Alex.... is it that simple? on the fls-2 schematics the line btemp jus goes to that pin on the fone via mod to battery? PS - THANX for replying..... if it is that simple, sure will help...... BR nokia_tec |
04-07-2002, 04:05 | #9 (permalink) |
Member: 1024 Status: Offline Thanks Meter: 5,510 | Hi, I have no way to check that on my 15000 RPM SCSI Cheeta, but must be working. If not , mail Daniel to do whatever patching needed in the Hex for making it so. Anyway I am not recomending you to use cracked software. BR, Alex |
jethro & dejan schmatic | AMTX99 | Nokia Hardware & Hardware Repair | 5 | 07-09-2008 09:46 |
Koci, B-Phreaks & Nokia Tool 035 | Seedy | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-22-2002 15:56 |
3330 & Dejan correct setting | rhd | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 11 | 09-13-2001 01:53 |
Jethro 3.31 & Dejan leads | Kam Singh | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 05-10-2001 10:49 |
Jethro software & Dejan leads??? | beatscientist | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 04-27-2001 13:06 |
