Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 02-21-2001, 22:16   #1 (permalink)
Batgoy's Avatar
Member: 3272
Exclamation Need solution for read "Atmel" & "AMD" flashes
Hi friends,
I need solution for read nokias with Atmel and AMD flashes. It is possible?
Thanks in advance.
Sirge
Old 02-21-2001, 22:50   #2 (permalink)
Member: 2785
Post
you can read 4kb at a time, for example, from 0020000 to 00201000 and so on, but that really sux. if anyone has a better solution...
Old 02-22-2001, 02:07   #3 (permalink)
Member: 3360
Thanks Meter: 4
Post
How about asking Dejan if he could make a loop in reading the address range (like 00200000 to 00400000) when the flasher is specified to read an ATMEL or AMD flash?
Old 02-22-2001, 12:32   #4 (permalink)
Member: 2785
Post
not a bad idea... try mailing him!
Old 02-22-2001, 16:58   #5 (permalink)
Member: 3191
Post
Need +5V VPP.....and Zener diode change..Only Atmel flash!
Beware of static electricity!!!!
Piranha
Hungarian GSM Team
Old 03-03-2001, 22:13   #6 (permalink)
Member: 3348
Thanks Meter: 3
Post
you can read an atmel chip by placing the atmel loader in nk-files.Then rename it to f_loader.bin. Then use the ms-dos flasher and do f1, then carry on as normal.you read totally fine.
dont forget to put your orinal loader back into nk-files after reading.
with regards wildwhacker.
Old 03-05-2001, 22:13   #7 (permalink)
Batgoy's Avatar
Member: 3272
Wink
Thanks with this solution. :-))))))
You see in to Flash.out - is kept FF OO FF OO........ only.
Best regards
Sirge
Page generated in 0.13244 seconds with 8 queries
