10-31-2001, 13:37 | #1 (permalink) |
No Life Poster Join Date: Aug 2008 Age: 52
Member: 1841 Status: Offline Thanks Meter: 469 | 3330 4.30 NEXT ATTEMPT!!! I need to collect as many different partials for this version as possible. Currently, I have only this partial: 29DA2F: 38 -> 5A<br />29DE7F: 38 -> 16 If anyone has another partial, please post it to this forum and/or send it to me to [email protected]. Thanks. |
10-31-2001, 18:23 | #3 (permalink) |
No Life Poster Join Date: May 2001 Location: Norway
Member: 4489 Status: Offline Thanks Meter: 2 | What we have only what we get from the net ,i think same as you have .<br />But if you find solution send it to me i will test it and give you result after 10 min.<br />Best regards |
10-31-2001, 19:28 | #5 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Madrid (from here to heaven) Age: 42
Member: 6084 Status: Offline Thanks Meter: 4 | someone unlocks 3330 v4.30 with 2 partials. why not to pacht new checksums wiht a second partials? One partial frees the phone, another repairs checksums. |
10-31-2001, 21:55 | #7 (permalink) |
Freak Poster Join Date: May 2001 Location: portugal
Member: 4550 Status: Offline Thanks Meter: 0 | I Lead, <br />I have some 3330 v.4.30 at home waiting for solution !<br />I can send you some partials flash, what are the adresses you need ??? And just one question, If I want to make 2 parts of 1 flash, suppose that the flash ad 4 megabytes,<br />and i want to make 1 half from 0020000 to 0040000 ??? (is this correct ??? ) for the second part what sould I take as start adress ??? 004a0000 or 0040000 ??? I dont whant to loose data but I donīt want to duplicate some data in the two half parts of the flash !!! I donīt know if you understand me, i hope you understand <img src="smile.gif" border="0"> So in 3330 what adress sould I put to get 1 flash whit ppm + 1 flash whit mcu + 1 flash whit eeprom ??? I donīt want to repeat some data in the 3 part of this complete flash, is like, if I had the word "message" and I want to split it in 3 part, I want to get "mes+sa+ge", and not "mes+ssa+age". Thanks for your help, and tell me what part of the 3330 you need. christophe [email protected] |
10-31-2001, 22:57 | #8 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | @maxximm: The range for the first part should be 200000-400000 and for the second it should be 400000-600000. The MCU range is 200000-490000.<br />The PPM range is 490000-550000.<br />Then the PMM and EEPROM follow - you should not overwrite them. I might be wrong, so please take care... |
11-01-2001, 18:31 | #9 (permalink) |
Member: 1841 Status: Offline Thanks Meter: 469 | FINALLY, I HAVE ALSO FOUND THE SOLUTION!!! Nobody sent me any useful info, so I decided to publish it later, in, say, three or four weeks. Francis Donnel was right. Two partials are necessary... one to unlock and the second to correct the damned MCU checksum. Btw., doing only this does not suffice... WBR, Lead. |
11-01-2001, 20:52 | #12 (permalink) |
Member: 4550 Status: Offline Thanks Meter: 0 | Hi Lead, Congratulations !!! Just need some help <img src="smile.gif" border="0"> Iīm also triyng to do that partial, but can you help me a little ??? I donīt want you to give me you partial, just need some info. 1 - WHit what soft do you correct the mcu checsums? ?? 2 - Can you tell me the adress of that checksum ??? 3 - Did you use the unlock partial that are in many web sites, or you make one partial by yourself ??? 4 - What do you mind whit "Btw., doing only this does not suffice... ", What trick is that, taht we have to make ??? I hope you will answer me<br />By the way, nice soft youīve done for Ericsson, changing logos etc ... christophe [email protected] <img src="wink.gif" border="0"> |
11-02-2001, 13:00 | #14 (permalink) |
No Life Poster Join Date: Apr 2001 Location: รำมว&#
Member: 3956 Status: Offline Sonork: galletto3 rules :D Thanks Meter: 55 | hi, first of all congratulations, I also want to know how the get the hell out of it, let me ask you, 1.- I assume first partial unlock phone<br />2.- Now the problem is ppm checksum, so instread of fix checksum I will patch the checksum routine so allways it get ok<br />where is located checksum?, best regards,<br />Invisible |
3330 4.50 downgrade to 3330 4.30 ? | nightxyz | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-13-2002 20:20 |
cant unlock 3330 4.30 lock 1,4 with Rolis | Cutty | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 01-18-2002 19:37 |
Nokia 3330 4.30 lock 4 klosed | Cutty | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 12-06-2001 01:03 |
3330 4.30 & 3310 5.03 Lock 1 Prob Solved! And Lock 4?! What to do??! | DSB2069 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 5 | 11-21-2001 15:13 |
Fls for Nokia 3330 4.30 and 4.50! | GSMUnlockDK | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 11-10-2001 17:24 |
