Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Nokia > Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L )
Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) Nokia Legacy Models Like 1011, 1610, 211x, 2x20, 6050, 3110, 8110, NKxxx , 2100, 3210, 3310, 3330, 3410, 5110, 5210, 5510, 6110, 6150, 6210, 6250, 7110, 8210, 8250, 8850 also 9110 & 9210
Old 06-18-2001, 22:43   #1 (permalink)
Member: 4398
Post Still got Problem with 8210, wont accept sim card can anyone help please???
the phone is totally unlocked (ive checked with nokia tool)
when i put a simcard in it still says please insert simcard as though it isnt recognising it.
Is there something i can do. Is the sim reader broken. If so can it be replaced and is there anyone in the UK that can fix it.
Please try to help.
Thanks
Simon Birley
Old 06-18-2001, 23:06   #2 (permalink)
Member: 3221
Post
Which f-loader and boot bin file did you use?
I've tried all the files I have bit still keep getting a boot data count failure or similar error. Can you help please?
Old 06-18-2001, 23:13   #3 (permalink)
Member: 4398
Post
i used the standard boot loader with my 8210.
its not a new one so it was okay.
can anyone help with the problem above.
Old 06-19-2001, 07:11   #4 (permalink)
Member: 3279
Thanks Meter: 19
Post
check your Sim Reader ,
Old 06-19-2001, 07:42   #5 (permalink)
Member: 3348
Thanks Meter: 3
Post
i have spare sim reader and service manual for the 8210, email me simberly.
Old 06-19-2001, 08:15   #6 (permalink)
Spalato's Avatar
Member: 2236
Thanks Meter: 56
Post
It is possible that the SIM reader has a failure althought that doesn't have to be the main reason. For example, when I unlock 6250 on some SW after unlock I get in Nokia tool 034 that phone is still locked but when I put the SIM card inside, the phone accepts it
I don't understand why it's so
Anyway, soon I will put for download a 100% working f_loader.bin file for the use with 8210 5.27...
Spalato
http://www.cro-web.com/maroon
Old 06-19-2001, 09:20   #7 (permalink)
Member: 3279
Thanks Meter: 19
Post
the fact that the message displayed is "insert sim card" and not "simcard not accepted" indicates that the problem is sim reader related
Old 06-24-2001, 03:21   #8 (permalink)
Member deceased !!
Member: 4983
Post
Hi all
I think maybe you flash your phone with a full flash of 2Mb and changed the IMEI with this, them the phone do not accept SIMs, all locka are closed by this (also if the Nokia Tools says are opened), they are all locks.
Solution is flash with the Dejan Box (not Dejan cable) and restore to the original IMEI with this Box.
I have one on the same situation of you of a friend of mine than do this .
Good Luck
Kilowat
[email protected]
Old 06-24-2001, 17:21   #9 (permalink)
Member: 3348
Thanks Meter: 3
Post
simberley please email me i have spare sim reader. i need postal info m8. i think you mailed me before but aol was messing about.
many apologies but the offer still stands.
many thanx. wildwhacker
Old 06-25-2001, 00:36   #10 (permalink)
Member: 5006
Thanks Meter: 2
Red face
I have given alot of good info on this forum. Can someone please rate me as a member, as all this good info. i am giving is not paying off, not even in a form of a thank you credit.
Rate and vote.
Old 06-25-2001, 22:03   #11 (permalink)
Member: 4398
Post
why should i rate you?
whT have you done to help me.
i just found out the problem is a flashing problem.
i got a new simcard reader but now it is the classic signal comes on for a few seconds then goes off.
obviously somebody has full flashed the phone.
Old 06-25-2001, 22:58   #12 (permalink)
yab
Member: 4847
Post
water damaged can result in this too....
Old 06-26-2001, 07:10   #13 (permalink)
Member: 4398
Post
ive had the phone open there doesnt appear to be any water damage
Old 06-26-2001, 09:02   #14 (permalink)
Member: 3165
After having a new SIM reader, now your phone is working fine. Problem is that it looses signal, right.
Do you still have the original backup when the phone came to you (lets disregard the idea that somebody else flashed it)? Is it the one that is currently on the phone?
If yes for both cases, then try this. When you loose signal, try pressing # then Call. If it gets back a signal after requesting then it just might be a signal problem. Take note though that you might have to do this several times before you get back a signal.
Alternatively you can try doing a manual network search and see if you get any signal.
I for one might think of this as a hardware error and not related to flash for in the first place, the SIM card reader was the problem earlier. Perhaps, this might be a dropped phone!
Regards,
aCe
Old 06-29-2001, 21:35   #15 (permalink)
vid
Member: 1367
Sonork: 88476
Thanks Meter: 27
Post
Hi,
Yes aZyWeRks & Kilowat are right,maybe you are flash it with 2mb file(with eeprom) or flash it differ of PPM pack.
1st you must check IMEI(*#06#)whether same with IMEI sticker(on back of phone),if same that maybe is differ of PPM pack.if that is not same you must flash back your 2mb backup(with eeprom).
Good Luck
Vid
can anyone help!! please!! matt81y GSM Mobile Links 0 04-11-2009 15:01
Sorry can anyone help please ! vinyl_pusher Nokia Multimedia 1 09-09-2008 22:39
u8180 with usim wont-accept sim card mmanduri LG 3G (USB-Smart) 4 04-22-2006 10:46
i killed my friend's t720i and the pc can't recognize it, can anyone help please? kev1234 Motorola P2k 3 01-30-2004 19:54
Page generated in 0.20468 seconds with 9 queries
