04-23-2001, 04:32 | #3 (permalink) | |
Freak Poster Join Date: Apr 2001 Location: Philippines
Member: 4215 Status: Offline Thanks Meter: 1 | I haven't tried it either but I actually saw the film place on top of the LCD. I tried moving the film but the screen goes blank. I think you also need to change the backlights to get an inverted LCD. Quote:
04-23-2001, 12:33 | #4 (permalink) |
Crazy Poster Join Date: Nov 2000 Location: Singapore
Member: 2688 Status: Offline Thanks Meter: 0 | the best way is to change the led to green or white then try to peel off the top layer platic of the lcd and turn it 90 degrees you will see it inverted Note: have to heat up the lcd before peeling off the top layer....very hard...do it slowly. |
04-24-2001, 00:35 | #5 (permalink) |
No Life Poster Join Date: Apr 2000 Location: Philippines
Member: 1272 Status: Offline Thanks Meter: 3 | use a razor blade... use wipeout to remove LCD film [top of the LCD] and use lighter fluid to clean LCD and just rotate 90 degrees. its better to have the backlight change to white otherwise, you wouldn't notice it |
04-24-2001, 15:54 | #6 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Philippines
Member: 4274 Status: Offline Thanks Meter: 18 | MDR is right, you should also need to replace the backlight with other color (blue, green or white) in order for you to appreciate the display.. and the film had also different color as you rotate it on either side.. |
04-24-2001, 17:24 | #7 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Netherlands
Member: 3561 Status: Offline Thanks Meter: 1 | On http://www.darkpower.de/ is a full description for Nokia 3210 and 3310 with pics about inverting display. It's in german... Here are some pics of the result http://n3210.purespace.de/invd.html |
04-24-2001, 21:07 | #8 (permalink) |
No Life Poster Join Date: Apr 2001 Location: Denmark Age: 45
Member: 4205 Status: Offline Thanks Meter: 9 | I don't understand german, does anyone have a english description (3210)? Can I break the phone by trying? Well, I have a broken display, I'll try with that one first... |
04-25-2001, 12:14 | #9 (permalink) |
Member: 4274 Status: Offline Thanks Meter: 18 | there's a possibility that you can damage the LCD and the film while you're removing it so be more careful... much better you should try doing it with your damage LCD... be careful... |
plz help L7 screen Inverted | LOOK_AT_ME_GOOD | Motorola P2k | 2 | 08-25-2009 01:42 |
Nokia 1110 screen invert | digitone | Nokia Hardware & Hardware Repair | 2 | 01-16-2008 09:40 |
T39 screen inverted ?? | Kobbra | Old Ericsson Phones & Sony Phones | 1 | 04-22-2003 09:07 |
Mobile Phone LCD Screen Inverter Foils>>> | logosunlimited | Main Sales Section | 0 | 12-28-2001 12:00 |
screen inverting | wildwhacker | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 9 | 12-07-2001 06:35 |
