Is there any way to repair "Contact Service" Using Dejan Flasher.? Is there any way to repair "Contact Service" Using Dejan Flasher.? |
You must tell us more! What a phone? What you did with phone! There can be many reasons for "Contact Service". Some yu can repair with Dajan! Contact me per mail! I will help you! Greetings MR... |
Hai MR.. Is it also possible to fix a 3210 v5.36 with contact service?? Created by pin trick. JVE |
Yes, but not with flasher, because 3210 has en external EEPROM (24c128). You will have to desolder it and read out by I2C-programmer, and fix the checksum! Greetings MR... |
hi can we fix 6210 contact service with nokia flasher. i bought a nokia 6210 with contact service at a very cheap price to take from it parts i decide to learn on it how to fix the contact service can naybody tell me how to fix this problem???? is it by flashing the phone full flash? thnx bye |
Hi everyone! I have the same problem, I full flsh my phone (3310 4.02) (0020000-00330000) and now it says: "CONTACT SERVICE", what should we do? Tkhs in advance :DCyberMania :D [email protected] |
hi guys, u know the easiest way to repair a CS unit is to; FIRST and foremost, backup the entire eeprom area if the phone has an emulated eprom (u'll find the info on adresses somewhere in the forum) and save it somewhere real safe. next, just full flash it with THE SAME firmware and ppm version. so when it says 4.19 euro, flash ONLY with 4.19 euro (copied from a GOOD and WORKING phone). next step is to upload the eprom part e.g for 3310 v4.02 u write eerom from add: 003D0000 and if the phone has no hardware problem at at all --- it will be alive and with network! otherwise, read more on how to repair broken unit (esp 3310) located somewhere in the forum. for units like 32 and 51, its another story -- read above! note: u dont have to remove the 24cXXx u can read and write on it in-circuit just be carefull when soldering wires or much better use super-tiny ic clips. dump eprom content and repair using bartek or guars checksum repairer, save and upload back to d phone -- u have it! and sometimes u need to do a full flash (same rules apply -- same version and ppm) :p |
