where to find a programmer for 16ce625-please help where can i find the programmer for programming 16ce625...can i use 16ce628 insted of 16ce625...<br />what is the exact value for the crystal used....<br />is it 8Mhz or 4Mhz...<br />thanking all zfrank friends...<br />harish [email protected] |
Here is the .inc file for your convenience: ; P16CE625.INC Standard Header File, Version 1.00 Microchip Technology, Inc.<br /> NOLIST ; This header file defines configurations, registers, and other useful bits of<br />; information for the PIC16CE625 microcontroller. These names are taken to match <br />; the data sheets as closely as possible. ; Note that the processor must be selected before this file is <br />; included. The processor may be selected the following ways: ; 1. Command line switch:<br />; C:\ MPASM MYFILE.ASM /PIC16CE625<br />; 2. LIST directive in the source file<br />; LIST P=PIC16CE625<br />; 3. Processor Type entry in the MPASM full-screen interface ;================================================= =========================<br />;<br />; Revision History<br />;<br />;================================================ ========================== ;Rev: Date: Reason: ;1.00 17 Dec 1997 Initial Release<br />;1.01 02 Apr 1998 Fix incorrect BADRAM and MAXRAM information ;================================================= =========================<br />;<br />; Verify Processor<br />;<br />;================================================ ========================== IFNDEF __16CE625<br /> MESSG "Processor-header file mismatch. Verify selected processor."<br /> ENDIF ;================================================= =========================<br />;<br />; Register Definitions<br />;<br />;================================================ ========================== W EQU H'0000'<br />F EQU H'0001' ;----- Register Files------------------------------------------------------ INDF EQU H'0000'<br />TMR0 EQU H'0001'<br />PCL EQU H'0002'<br />STATUS EQU H'0003'<br />FSR EQU H'0004'<br />PORTA EQU H'0005'<br />PORTB EQU H'0006'<br />PCLATH EQU H'000A'<br />INTCON EQU H'000B'<br />PIR1 EQU H'000C'<br />CMCON EQU H'001F' OPTION_REG EQU H'0081'<br />TRISA EQU H'0085'<br />TRISB EQU H'0086'<br />PIE1 EQU H'008C'<br />PCON EQU H'008E'<br />EEINTF EQU H'0090'<br />VRCON EQU H'009F' ;----- STATUS Bits -------------------------------------------------------- IRP EQU H'0007'<br />RP1 EQU H'0006'<br />RP0 EQU H'0005'<br />NOT_TO EQU H'0004'<br />NOT_PD EQU H'0003'<br />Z EQU H'0002'<br />DC EQU H'0001'<br />C EQU H'0000' ;----- INTCON Bits -------------------------------------------------------- GIE EQU H'0007'<br />PEIE EQU H'0006'<br />T0IE EQU H'0005'<br />INTE EQU H'0004'<br />RBIE EQU H'0003'<br />T0IF EQU H'0002'<br />INTF EQU H'0001'<br />RBIF EQU H'0000' ;----- PIR1 Bits ---------------------------------------------------------- CMIF EQU H'0006' ;----- CMCON Bits --------------------------------------------------------- C2OUT EQU H'0007'<br />C1OUT EQU H'0006'<br />CIS EQU H'0003'<br />CM2 EQU H'0002'<br />CM1 EQU H'0001'<br />CM0 EQU H'0000' ;----- OPTION Bits -------------------------------------------------------- NOT_RBPU EQU H'0007'<br />INTEDG EQU H'0006'<br />T0CS EQU H'0005'<br />T0SE EQU H'0004'<br />PSA EQU H'0003'<br />PS2 EQU H'0002'<br />PS1 EQU H'0001'<br />PS0 EQU H'0000' ;----- PIE1 Bits ---------------------------------------------------------- CMIE EQU H'0006' ;----- PCON Bits ---------------------------------------------------------- NOT_POR EQU H'0001'<br />NOT_BO EQU H'0000'<br />NOT_BOR EQU H'0000' ;----- VRCON Bits --------------------------------------------------------- VREN EQU H'0007'<br />VROE EQU H'0006'<br />VRR EQU H'0005'<br />VR3 EQU H'0003'<br />VR2 EQU H'0002'<br />VR1 EQU H'0001'<br />VR0 EQU H'0000' ;----- EEINTF Bits ---------------------------------------------------------- EESDA EQU H'0001'<br />EESCL EQU H'0002'<br />EEVDD EQU H'0000' ;================================================= =========================<br />;<br />; RAM Definition<br />;<br />;================================================ ========================== __MAXRAM H'0FF'<br /> __BADRAM H'07'-H'09', H'0D'-H'1E'<br /> __BADRAM H'87'-H'89', H'8D', H'8F', H'91'-H'9E'<br /> __BADRAM H'C0'-H'EF' ;================================================= =========================<br />;<br />; Configuration Bits<br />;<br />;================================================ ========================== _BODEN_ON EQU H'3FFF'<br />_BODEN_OFF EQU H'3FBF'<br />_CP_ALL EQU H'00CF'<br />_CP_75 EQU H'15DF'<br />_CP_50 EQU H'2AEF'<br />_CP_OFF EQU H'3FFF'<br />_PWRTE_OFF EQU H'3FFF'<br />_PWRTE_ON EQU H'3FF7'<br />_WDT_ON EQU H'3FFF'<br />_WDT_OFF EQU H'3FFB'<br />_LP_OSC EQU H'3FFC'<br />_XT_OSC EQU H'3FFD'<br />_HS_OSC EQU H'3FFE'<br />_RC_OSC EQU H'3FFF' LIST |
