06-19-2001, 19:20 | #1 (permalink) |
Major Poster Join Date: Jun 2001 Location: Cyprus
Member: 4903 Status: Offline Thanks Meter: 0 | problem with flasher? I use dejan flasher to read full flash a 3310 phone v. 4.35 and to flash another 3310 v.4.35. I did that because the phonei read the full flash had a language i wanted to put to the other phone. After, i wrote the full flash using NK-FLASH2 cable to the other phone, but the phone now is dead. Could you give some advise why this may happened even though the phones have the same software versions? Is the flasher not working correct to read a flash? And another question, when i full flash a phone then its imey number changes? And if yes what program can i use to give its original imey number back? Thanks in advance, Dimitris |
06-20-2001, 13:42 | #2 (permalink) |
Insane Poster Join Date: May 2001 Location: Slovakia
Member: 4808 Status: Offline Thanks Meter: 0 | I have this problem also, but with 6210. Nobody say a useable solution for this! Only dejan 1.04 can make this! If you do some good steps in it, say me please! celo. |
06-20-2001, 19:01 | #3 (permalink) | |
Insane Poster Join Date: Jan 2001 Location: Latvia Age: 52
Member: 3022 Status: Offline Thanks Meter: 1 | Quote:
1. If you made dump before flashing, just flash back original data 2.If you don`t made dump - BAD! You must have other dead NOKIA 3310 (like water damaged or hard mechanical damadge) from this one you must desolder with hot air COBBA IC(V257B/4370643)and FLASH memory, than solder this two IC in you killed phone, that`s all! Hard way but i don`t know other solutions P.S. 1.You can`t changing language without changing FlashAutorityID, because version of PPM packages different, you can read many many topics about this problem on this Forum. 2.One more mistake, full flash of NOKIA 3310 contain EEPROM data too! Sorry for my English! | |
Problem with flasher db2020 | neo25_gsm | FuriousGold | 3 | 11-22-2007 10:29 |
V1050 problem with flasher... | v11 | Smart-Clip | 12 | 06-07-2006 12:30 |
3330 Unlocking problem with Flasher Cables... | richieH | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 8 | 12-11-2003 18:17 |
Please! I need help! Problem with flasher DCT4. | KisaKot | Nokia Digital Core Technology 4 ( DCT-4 ) | 7 | 05-06-2003 23:02 |
Problem with flasher | abuissa | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 6 | 11-04-2001 16:11 |
