1200 1208 and 1650 ???????????? solution [.imei patch] 1200 1208 and 1650 ???????????? solution [.imei patch] 1-put PATCH in MCU. 2-PPM and CNT asuaual (Ver 4.11)must. 3-Tick on UI and UNLOCK options. 4-When unlock patch ask file, give same patch which use in MCU. 5-Tested on 1200 1208 and 1650. http://rapidshare.com/files/132846998/Patches.rar |
This patch is use for imei change not imei currupt ????????? Imei currupt is solve to using ASK2RPL service:) |
yes i think its just for change .. imei |
yes only change imei................... |
This is only way to change IMEI of the engine and Buckcassing |
if the imei is like this ???????????????, you need buy rpl. dont post this, is not true........ |
in this way u can change only ime. If ime is crupted . In this way its ok but signal not found |
signal can be found but after 30 sec set goes off fail procedule and old procedure already tested thabks................ |
And also its a fake thread................................. |
1208 [QUOTE=samirov-gsm;4262752]1200 1208 and 1650 ???????????? solution [.imei patch] 1-put PATCH in MCU. 2-PPM and CNT asuaual (Ver 4.11)must. 3-Tick on UI and UNLOCK options. 4-When unlock patch ask file, give same patch which use in MCU. 5-Tested on 1200 1208 and 1650. it is ok solution but after some time mobile set off ..it is problem |
good work...... nice share.... |
Getting MCU ID MCU ID: 0x2292 FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Checking RAM for ALGO... Algo is ready... Checking FAID calculation... P-key nokia module version 01.02 Done! Phone Restarted... FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: \Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... Error Auth! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Switching to serial... Powering the phone... Failed! Aborting! Backup IMEI zone... Setting local mode... Failed! Aborting! Getting MCUID... MCU ID: 0x2292 Reading flash chip detailes... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 018F0000 - 018FFFFF Phone didn't answer with TX line low after UEM reset! Causes: 1. put a 27-33 pico capacitor in connector b/w mbus-gnd. 2. UEM damaged -> replace uem. MCU ID: 0xDDDD Error booting phone... MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Error erasing area: 01010000 - 0101FFFF MCU ID: 0x2292 Boot is ready... Algo is ready... Loader is ready... Erasing area: 01000000 - 01FFFFFF... Done! Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Searching for default location of ini... Checking path: \Products\RH-99\ Searching for JAF saved location of ini... Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ Scanning ini files... Checking path: \Products\RH-99\ Checking path: C:\Program Files\Nokia\Phoenix\Products\RH-99\ FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.91aa CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh990_nai5.91aa ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Dannish,Norwegian,Swedish MCU: C:\Program Files\Nokia\Phoenix\Products\RH-99\rh99_05.910 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... Error Auth! help me after patching and edit imei |
************yes only change imei.*************** ******************************************* |
JAF version 1.98.62 Detected PKEY:EXTREME_CSC Card life counter: 54.83% P-key nokia module version 01.02 Detected UFS_USB V2.8 (c) SarasSoft 2007. version: 01.B1, Driver version: 0, Library version: 0 JAF DCT4/BB5 LOADERS DIR: C:\Program Files\ODEON\JAF\Flash\ JAF DCT4/BB5 PRODUCT DIR: C:\Program Files\Nokia\Phoenix\Products\ JAF USB LOADERS DIR: C:\Program Files\ODEON\JAF\FlashUSB\ JAF DCT3/DCTL LOADERS DIR: C:\Program Files\ODEON\JAF\Flash3\ USB Cable Driver version: 7.1.8.0 FILES SET FOR FLASHING: MCU Flash file: NONE PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: NONE CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej CNT Flash file: NONE ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Phone Type: FILES SET FOR FLASHING: MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej ADSP Flash file: NONE APE Variant file: NONE APE User Flash file: NONE Languages in ppm: English,Russian,Ukrainian Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: A9 7E B2 1A 1B BE 0B E2 79 58 6B E4 DB EE 61 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 31 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 13 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: A9 7E B2 1A 1B BE 0B E2 79 58 6B E4 DB EE 61 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 845CA632296C80AA892FC5C96C MSID decoded: 3E4EBAE9005F4B85AA000000 FAID: 0A7921C78107EA9E5FA2E198 Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 9 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 7 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 0 seconds... Restarting MCU... Operation took 0 minutes 1 seconds... Flashing Done! Operation took 2 minutes 30 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.11 IMEI: ??????????????? Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 7 seconds... Done! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 011E0000 - 011FFFFF... Erasing area: 011E0000 - 011FFFFF... Unlocking... Simlock data rejected! Code: 0x13 Failed! Aborting! Setting local mode... Reading imei... IMEI/ESN: ??????????????? Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Documents and Settings\Administrator\Desktop\Patches\RM-305_V_4.11_359563015568458_patch.mcusw Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 01200000 - 0121FFFF... Erasing area: 011E0000 - 011FFFFF... Failed! Aborting! Backing up PM Field 208 as RPL... Setting local mode... Failed! Aborting! Failed to backup imei... MCU: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.110 Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 16 seconds... Erasing... Found 5 interval(s) to erase Erasing area: 01000000 - 0100FFFF... Erasing area: 01010000 - 013AFFFF... Erasing area: 013B0000 - 013EFFFF... Erasing area: 017C0000 - 017EFFFF... Erasing area: 01FC0000 - 01FEFFFF... Operation took 0 minutes 30 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 13 seconds... Restarting MCU... PPM: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh105_04.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 845CA632296C80AA892FC5C96C MSID decoded: 3E4EBAE9005F4B85AA000000 FAID: 0A7921C78107EA9E5FA2E198 Operation took 0 minutes 16 seconds... Erasing PPM... Found 2 interval(s) to erase Erasing area: 01240000 - 0124FFFF... Erasing area: 01250000 - 0137FFFF... Operation took 0 minutes 10 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 6 seconds... Restarting MCU... CNT: C:\Program Files\Nokia\Phoenix\Products\rh-105\rh1050_nai4.11ej Booting phone... MCU ID: 0x2292 BOOT file: C:\Program Files\ODEON\JAF\Flash\u3_2nd.fia Loader version: 04.46.01 -> Revision: 0007 Boot size is 0x09A8 Boot is ready... FLASH ID0: 226800EC <=> SAMSUNG (SEC) -> K8S3215ETE Addr0: 0x01000000 - 0x01FFFFFF, SectorSize0: 10 FLASH ID1: 00010000 <=> Flash -> not used Addr1: 0x02000000 - 0x02FFFFFF, SectorSize1: 0 First 16 bytes: AD 7E B6 1A 1B BE 0B E2 7D 58 6B E4 DB EE 65 14 Flash ID is 0x6822EC00 Flash loader is C:\Program Files\ODEON\JAF\Flash\u3_amd.fia Loader version: 04.46.01 -> Revision: 0007 Loader size is 0x7528; Loader chk: 50 Loader is ready... P-key nokia module version 01.02 MSID: 8490DD5FEDA2A2461682F3240E MSID decoded: 3E4EBAE9005F4B85A9000000 FAID: 8BBA364576790F369075B350 Operation took 0 minutes 15 seconds... Erasing Content Pack... Found 1 interval(s) to erase Erasing area: 01380000 - 013AFFFF... Operation took 0 minutes 2 seconds... Writing... Perm. Data Restore OK Operation took 0 minutes 1 seconds... Restarting MCU... Operation took 0 minutes 0 seconds... Flashing Done! Operation took 2 minutes 30 seconds... After flash processing... Waiting for phone to boot... Reading... Phone type: RH-105, Software version: 4.11 IMEI: ??????????????? Product Code: Resetting PPC... Setting FULL FACTORY......Setting test mode... Setting FULL FACTORY... Operation took 0 minutes 8 seconds... Done! Done! Powering the phone... Unlocking... IMEI: ??????????????? ASIC: b SW version: 4.11 Selected flash file: C:\Documents and Settings\Administrator\Desktop\Patches\RH-105_V_4.11_358088001236580_patch.mcusw Decrypting flash... Encrypting.... CHK Patch found - Unlock Patch found and are not in same block Patch status: 02 MCU ID: 0x2292 Algo is ready... P-key nokia module version 01.02 Erasing area: 011E0000 - 011FFFFF... Erasing area: 011E0000 - 011FFFFF... Unlocking... Checking locks... Block 1: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 2: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 3: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 4: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 5: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 6: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Block 7: Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN Done! DCT4 unlock counter: 1 Setting local mode... Reading imei... IMEI/ESN: 350016000211112 Reseting warranty data... Reseting LifeTimer... Lifetime data not found!!! Done! I did it.. thanks to the tread starter... |
