1600 Contact Service Problem Hi, i have 1600 showing COntact Service. When i connect with UFS-3, it shows Local Mode on screen and gives Info but when i click on Check or want to erase, it gives First Boot Error.I didn't unersatnd what the problem is with fone. Any body please, help me with only UFS-3 :mad: Your response will be highely appreciated. |
check cable and battery connector and try flash the phone v 3.42 mcu+ppm+cnd then unlock...regards |
Big thanks for ur quick reply i will do as you said and then will post result:) |
Conecting Ufs Quote:
1st Boot Err: Bad Resp UFSx Rebooting Mobile "ITS MEAN NOT RESPONDING UFS.THAN RESTART UR COMPUTER AND TRY AGAIN .IT SHOW THIS MESSAGE "1st Boot Err: Bad Resp UPP, 03 00 00 72 1st Boot Err: Bad Resp DCT3, 00 93 5 Rebooting Mobile " ITS MEAN UR CABLE IS OK AND U NEED TO ADJUST UR CABLE PINS WITH PHONE SOFTWARE POINTS. |
Firstly, Cable is 100% ok bcz at the same time i flashed 1100 with same cable and many other 1100,1110,1110i or 1112. Secoendly, this error message is showing to me "1st Boot Err: Bad Resp UPP, 03 00 00 72 1st Boot Err: Bad Resp DCT3, 00 93 5 solution for this problem you suggest, i don't think so bcz as we know fone place where we insert cable is as according to cable, so i think it's not the case. I didn't ever encouter this kind of problem Regards |
Brother Sultion post already plz search fourm |
computer configration error for flahloaders 10000000000000000000000% [email protected] |
Use other Box to solve problem. |
imei number write problem! |
i have 1600 contactservice problem i try full flash done but problem is same |
pls provide full details regarding to solve the problem if any body have. |
i Have 1110i, 30 sec after auto off please give me sollution, i first errase flash update file. give good pm file but same problem |
