2300 blink after write full PM with Twister I have a 2300 which has security code . I tried to reset it and nothing . Then I wrote full PM with Twister and ... surprise ... the famous blink . What can I do ? |
1. Do "erase flash" using same function in DCTx software. 2. Write MCU and PPM 3. Write good PM, unlock, make reset. |
Full PM were taken from the support ftp of the twister . And what do you mean "good PM " ? THX !!! |
is it show imei initilization failed when unlock |
Not That way Quote:
Fo this phone, here is what to do: 1. Using "Erase Button" Erase all flash areas 2. Write Full Flash (MCU + PPM) Its better to use the latest flash pack. 3. Write PM from Support area (Thats what he means by "Good PM" 4. Init Simlock 5. Full Factory Defaults. 100 % Factory phone again. |
hi I have a problem with 2300 phones, after fulll flash with mcu & ppm flash, no network. Then when i uplaod pm, i get blank screen. I use ufs3. i have about 6 of these phones. |
@Dexter2 Quote:
I hope u also insi simlock and ull factory. Do and see. I have 2 that after everything, I cannot set full factory. All works, but after init simlocks, full factory will not work, then phone has BLACK DISPLAY (nothing showing). Solution ??? |
...........display is white |
@dannyogolo is there solution for broken uem, for 2300 with bad imei:???????????????04. After full flash i get sim not valid. Thanx man. |
?????????????4 Solution exists, but the phone is too cheap for the solution to be implemented here. I will make 2x the money using same time to fix one A800 connector, and after that I "shine" myself with a bottle of STAR Lager |
Can anyone tell me what is UEM ? Is it IMEI of DCT4 ? |
uem? Quote:
can some one help me , i need 2300 latest flash file , where can i get ? now my vesion is RM-5 3.44 |
U can download latest flash file from suporting area,now is v5.60.contact ur reseller for user&pass for suporting area. regards santhosh :eek: |
