2600 No Charge Solution 1 Attachment(s) 2600 No Charge ,i Find Shorting Of Two Point Of Charging Pin And Repaired 5 Phones In This Way |
The picture is not clear,could you explain what have to do! |
Hello Baygan . Please can u Do me an Avatar like u :D :D :D I think everyone like it :D BR |
but what means Baygan |
i will try to upload another pics again |
1 Attachment(s) draw ways here, it's clear ;) |
This does not work.He says you must solder a wire from + point on charge connector to + point of diode.This means you dont have to remove fuse and coil....NOT WORKING |
HI IT can work provided that your charging is damaged in this way. he is eliminating the positive feed from the positive pad and linking direct to the diode. he eliminates the fuse so that the curcuit gets canceled from the positive pad because at that particular point the positive and negative is shorting regards reo |
1 Attachment(s) THANKS MBtech for uploading here i m uploading another clear draw ,same process works in 1100/2300 also mostly in water damages set and when input (+)and(-) pad are shoting and fact is i repaired 3 pcs(2600) and 4 pcs (1100) in that way. |
pls if you have any other solution, coz i tried your solution but still no response on charging |
not work .......................... wbr |
it was really nice having you here |
@that solution work only if charging input point both are shorting remove F100 and L100 and connect direct input (+)ve to v100 and in that way charging volt directly gone to v100 and make a patch at pcb input (+)ve point because i find shorting at pcb(+)ve point .if we not remove F100/L100 reverse volt to (+)ve point make shorting again. it works fine ,i tested it u try it again |
reeal nice info..... i used to think it was a problem with the UEM or current IC |
if i understand you; Remove F100 and L100. then put a jumper wire from the positive terminal of the charger input directly to v100? that's all? |
