3220 flash problem 2 Attachment(s) 3220 flash ok but no local mode or test mode on lcd & whene i try init simlock give error & not power on any 1 have a solution :confused: :confused: :eek: |
Check IMEI if OK, Try to Patch. |
check your imei...if it is still ok, flash it with jaf, phones like 3220 and 6220 can be easily revive with jaf... |
thanks for replay brs but i dont found any working patch for 3220 |
try to flash with cnt also try with jaf |
cant read info thanks br |
try to flash CNT, it cause this probleme . . . try and post . . . |
i do that & flash compleate ok & phone still off |
don't forget to check power switch |
1 Attachment(s) witch log br this one |
Dear reinstall ufs install latest ver. then flesh with latest ver. with normal speed and chose diff files, try two r three times it will give some error with ufs but after two to three try flesh 100% try and post result and BEST is JAF POST RESULTTTT |
try to use erase flash then write mcu,ppm,cnt with the older version after the procedure has done immediately re-write with the newer version of mcu,ppm,cnt then write pm ful fact init. thats all |
Erase Full flash Area 0x01000000-0x01FFFFFF Then flash with latest version 05.90 mcu+ppm+cnt after flash write good pm , init simlock + Ui settings post result |
please any one have cnt 64 kb please upload it &many thanksfor all helpfull members |
