6230 lights hi can any one help i have a 6230 water damage its fixed but no lights what can i do. :D |
i have one with this problem but can't fix it now Somebody have tip or solution to fix it? Thanks kjgsm |
check the connector where LCD goes on the main board , just clean it properly it mite be rusty , check both connectors infact lcd and main board !!!!! good luck |
there is also a driver for the LED,s wich may have become faulty i have 2 of these phones will post here if they get repaired i think it is the glass ic just under the left side keypad connectors next to the flash but i may be wrong have to finish tracing the problem |
6230 no light hello i can find the problem the 6230 water damage , have one small IC 8 pins upper voltage 4V to 12 V to lcd , can find in under imei lable , replace it can fix 100% |
are you talking about N300 white LED driver ? |
replace the small coil at the same time, that often causes problems after h20 damage. |
