6230b to 6230 Euro conversion Cash reward for conversion schematics, please send ICQ message to 267-827-669 if you have a solution thanks |
look into 6230 level 3/4 service manual at portal.sedf.net firmware is the same, in addition you have to make band reselection with phoenix service software (pkd-1 dongle or PBB required) |
a fast question before i start digging, are they true SMT components that need replaced or simple jumpers like the 6800 conversion? thanks please advise. |
Hi try reading the PM yourself from a 6230. keep us posted on your results plz. reo |
change: C810,Z808 ,Z700 and G501 use pm 6230 normal ,unlock ,full factory,repair BT and ok big import G501 vctcxo 2.7v 26MH+-2PPM gsm else signal drop when call this is big secret no need special pm(1500$) |
pm 6230 1 Attachment(s) pm standard attach!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! \ |
"use pm 6230 normal ,unlock ,full factory,repair BT and ok" which tool/box/sw do you use to repair BT?? I have 6230b coinverted to use in europe. The signal is now quite ok, the 900m filter was removed from the board, but BT function doesn't allow to be turned on in phone menu. Othervise works quite ok |
tornado flasher Dctx_Ufs_Ins_13j.exe |
after tow day phone to do same(signal drop when call) I tired NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
well i never find such replayes in any sites talking in this subject |
Could someone help with the 6800 Conversion? itīs a 6800a and itīs IMEI begins with "0". I need it to work in 900Mhz. |
